Author Topic: Quick question.  (Read 2577 times)
Offline Hydroid
    • http://justin.tv/hydr0id
Quick question.
« on: Wed, 01 February 2012, 06:16:19 »
Well it's late at night and after a quick search I didn't find anything. Are the WASD keycaps compatible with either a Ducky or Leopold? If they are I'm going to place an order for some custom keycaps to pimp out my keyboard before going to an SC2 tournament later this month.
Intel Core i7 870 @ 2.93GHz | Corsair H50 | 16GB G.Skill DDR3 | Asus P7P55D-E Pro | Galaxy nVidia GeForce GTX 460 SLI
OCZ 60GB SSD | 2x 1TB Seagate Barracuda RAID-0 | Samsung Blu-Ray Burner | Corsair HX-850W | 2x BenQ G2420HD 24"
Leopold FC200R Tenkeyless Blue | Ducky DK9008(B) Blue | Qsenn DT-35 Black PS/2 Rubber Dome |2x Razer Lycosa USB | Microsoft 500 PS/2
Help me support and grow e-sports below!!!
What Happens in Starcraft -- Vlogs -- Twitter
Offline reaper
Quick question.
« Reply #1 on: Wed, 01 February 2012, 06:27:01 »
Yes, they are.
Din Eli
Offline Hydroid
Quick question.
« Reply #2 on: Wed, 01 February 2012, 06:40:50 »
Cool thanks, I was a little concerned about the stabilizers not being compatible.
Offline Armando Penblade
    • http://thegeekery.org
Quick question.
« Reply #3 on: Wed, 01 February 2012, 08:36:32 »
AFAIK, they're not, are they? WASD are Costar-manufactured, while at least Duckys use Cherry stabilizers.
Filco Majestouch 104-US, Metallic Blue, with Chery MX Blues  //  Microsoft Comfort Curve 2000, 104-US + Media Keys & Browser Controls  //  iRocks RF-6570 Cordless 104-US, 2.4GHz Wireless, White  //  SteelSeries 6Gv2 104-US, Black, with Cherry MX Blacks
Offline alaricljs
  • I be WOT'ing all day...
Quick question.
« Reply #4 on: Wed, 01 February 2012, 09:23:45 »
Doesn't matter what type of stabilizer.  Only thing that matters is whether the space bar has the right spacing on the stabilizer stems.  Every other keycap has standardized spacing for stabilizers.
Filco w/ Imsto thick PBT
Offline reaper
Quick question.
« Reply #5 on: Wed, 01 February 2012, 09:26:04 »
Quote from: Hydroid;505128
Sorry but your op didn't state anything about stabilizers.  I thought you were asking only about keycaps.
Sent from iPhone!
Din Eli
Offline lightsout714
Quick question.
« Reply #6 on: Wed, 01 February 2012, 10:10:14 »
Not sure if the WASD spacebar will fit on a leopold.
Sent from my Galaxy Nexus using Tapatalk
Offline tsangan
  • 1000/600
Quick question.
« Reply #7 on: Wed, 01 February 2012, 10:25:29 »
Quote from: lightsout714;505268
They don't fit, you'll need to mod them for Leopold
Keyboardless
Offline Hydroid
Quick question.
« Reply #8 on: Wed, 01 February 2012, 17:34:19 »
Well I guess I'll find out the hard way, because I placed the order immediately after the first response and went to bed. Although I'd assume that the implication with keycap compatibility is concerning stabilizers seeing as all the regular keycaps should be compatible with all cherry switches.
Quick question.
« Reply #9 on: Wed, 01 February 2012, 18:50:06 »
No its not the stabilizers. The hole in the space bar where the stem goes is in a different spot on a leopold then it is on the other brands.
This guy sells pre-modded (if he has any) space bars or can mod yours.
http://geekhack.org/forumdisplay.php?90-TheProfosist
Offline Hydroid
Quick question.
« Reply #10 on: Thu, 02 February 2012, 03:10:48 »
Exactly the holes where the stabilizer stems go into are what I was questioning. That's still part of the stabilizers though.
Quick question.
« Reply #11 on: Thu, 02 February 2012, 08:57:29 »
I guess. But when you say it like that it sounds like every cap has a stabilizer then. Just clarifying.
