Author Topic: MX red springs with MX blue switches  (Read 4388 times)
Offline WhiteFireDragon
    • youtube
« on: Wed, 01 February 2012, 23:03:56 »
I just got my first board with MX red today, and I just love how light and smooth the switches feel. However, I also love the clicky feel of my MX blue switch. To get the best of both worlds, I plan on swapping all the springs inside my MX blue switches with the light springs from red switches. Is this a good idea? Has anyone done this before? I don't mind desoldering if I have to.
What's the cheapest keyboard I can buy to harvest red switches from?
Offline pitashen
« Reply #1 on: Wed, 01 February 2012, 23:07:33 »
If I am not mistaken:
mx red spring + mx blue stem = mx blue
Offline daniel0731ex
« Reply #2 on: Wed, 01 February 2012, 23:09:20 »
From what I heard:
Red spring = brown spring = blue spring
Black spring = white spring
"I hated the Blackwidow. Hated, hated, hated, hated, hated the Blackwidow. Hated it. Hated every cheapening feeble useless user-insulting gimmicks of it. Hated the keycap font that thought anyone would like it. Hated the marketing pretense to the keyboard by its belief that anyone would be impressed by it."
Roger Exbert - The Number One Keyboard Critic On The Planet.
Offline Gin
« Reply #3 on: Wed, 01 February 2012, 23:09:36 »
It will feel exactly like a blue.
Offline pitashen
« Reply #4 on: Wed, 01 February 2012, 23:13:27 »
guess the above confirmed my suspicion.
Unfortunately your best bet of having the best of both worlds is actually getting mx brown.
« Reply #5 on: Wed, 01 February 2012, 23:14:45 »
http://geekhack.org/showwiki.php?title=Cherry+Corporation+Switch+Wiki#Red:
"Springs are identical to Cherry Blue/Cherry Brown springs."
And also, what is your keyboard? Many keyboards have plate-mounted switches so you can't really swap the internals.
    • youtube
« Reply #6 on: Wed, 01 February 2012, 23:16:06 »
Red and blue springs are exactly the same? :noidea:
I thought red was lighter than browns, which are lighter than blues.
« Reply #7 on: Wed, 01 February 2012, 23:19:06 »
Quote from: WhiteFireDragon;506000
If you think about it, it's pretty obvious.
The additional resistance you feel is caused by the bump on the stem pushing the leaf spring in the keyswitch. Therefore the larger the bump = more force required.
And since linear switches have no bumps, it does not add any extra force feedback to your finger other than those from the spring itself.
Offline pitashen
« Reply #8 on: Wed, 01 February 2012, 23:29:03 »
Quote from: daniel0731ex;506003
It is not that obvious until you look at the force plots and those cheesy switch animations :P
Offline stingrae
« Reply #9 on: Thu, 02 February 2012, 00:11:14 »
ofcourse there is always modding the blues to browns lol
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline biolaser
« Reply #10 on: Thu, 02 February 2012, 00:37:55 »
I guess the solution would be to get springs of the correct size that are even less stiff than the red/blue/brown ones. But maybe springs aren't as simple as that. I wonder if anyone has attempted a mod like that here.
Choc Mini, QFR, Poker (MX Red) | Realforce 86U(v), 91UBK(v), 103UB(55) | AT101W | ABS M1 | Blue MJ2 (MX Brown) | Das Pro S (MX Blue)
Offline slueth
« Reply #11 on: Thu, 02 February 2012, 00:40:06 »
At least we told you before you started modding, ahahh the disappointment.
Offline Gawkbasher
« Reply #12 on: Thu, 02 February 2012, 00:42:31 »
What red keyboard did you end up getting? :D
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
    • youtube
« Reply #13 on: Thu, 02 February 2012, 01:15:04 »
Quote from: daniel0731ex;505999
Both blue and red switches are Filco. Yes, they're plate-mounted, but I mentioned I'm willing to desolder both to mod it into the perfect switch.
Quote from: pitashen;505994
I tried browns, not a fan of them. The subtle tactile bump actually makes it feel worst for me, because then it's not smooth, nor does it have enough feel/noise feedback. I just wanted something like blues, but with a lot less force. I think that would be my perfect switch.
Quote from: Gawkbasher;506115
I ended up getting the Filco 104 full size reds. The funny thing is, I bought it from lootbag and he shipped it right before he posted up his red poker in the classified. It's the poker that I really wanted and been searching for.
fossala
  •  Guest
« Reply #14 on: Thu, 02 February 2012, 01:57:47 »
Quote from: daniel0731ex;505987
From what I heard:
Clear and black springs are not the same.
« Reply #15 on: Thu, 02 February 2012, 16:10:34 »
Quote from: ripster;506417
Hooke's law.
Fix'd
And yes, I checked the wiki again and both the photo and the force graph shows that white springs are stiffer than blacks.
I wonder if anyone tried to put black springs in a white stem before?
