Author Topic: Key mapping  (Read 3210 times)
Offline 443330
Key mapping
« on: Wed, 01 February 2012, 23:40:04 »
Hi guys, I am wanting to map my left windows key on my Poker to a Fn Key. What would be the best method?
Also I have noticed my left shift has a squishy feeling, is this caused by the stabilizer? And how can I make the key feel more crisp?
Cheers.
Offline biolaser
Key mapping
« Reply #1 on: Thu, 02 February 2012, 00:03:56 »
For the key mapping, I think autohotkey will do the trick. For the squishy key, I dunno.. but other people here do!
Choc Mini, QFR, Poker (MX Red) | Realforce 86U(v), 91UBK(v), 103UB(55) | AT101W | ABS M1 | Blue MJ2 (MX Brown) | Das Pro S (MX Blue)
Offline 443330
Key mapping
« Reply #2 on: Thu, 02 February 2012, 00:06:09 »
Thanks, Is there an alternative to Autohotkey? I would prefer the simplest method so I don't have to run a program constantly.
Offline 443330
Key mapping
« Reply #3 on: Thu, 02 February 2012, 00:07:38 »
Offline vortex
Key mapping
« Reply #4 on: Thu, 02 February 2012, 00:23:25 »
Hi, If you got skype account , I can teach you how to method that :)
Just give a PM
Quote from: 443330;506048
Cheers.
Offline 443330
Key mapping
« Reply #5 on: Thu, 02 February 2012, 00:25:39 »
Hi Vortex, thanks for the kind offer but unfortunately I do not have a skype account :c.
About remapping the Windows key to the FN key can I do this manually using regedit? And if so what values do I need to change?
Offline 443330
Key mapping
« Reply #6 on: Thu, 02 February 2012, 02:46:20 »
Hmm does anyone have any idea as to why when I tried to remap my Caps lock to escape by editing the registry it did nothing?
I navigated to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout
and created a binary value named Scancode Map
I then input the correct numbers in the correct format and rebooted. But it didn't change a thing :c
Offline forcefollow
Key mapping
« Reply #7 on: Thu, 02 February 2012, 06:00:08 »
sharpkeys won't do, tried that before..
Cheers.
I think the easiest way to do this in poker is via the dip switch..
dip switch 4 if I'm not mistaken
remember to unplug first before changing the DIP switch. If that still wont work, try restarting before re-plugging the keyboard
Edit: here's my poker manual
Offline qwxc
Key mapping
« Reply #8 on: Thu, 02 February 2012, 06:04:57 »
+1 for forcefollows suggestion. Although the DIP switch for it is 1 :D. Easy peasy!
Also switching ctrl and caps is highly recomended, DIP for that is 2.
Offline 443330
Key mapping
« Reply #9 on: Thu, 02 February 2012, 06:11:17 »
Awesome, can some one explain to me what each DIP switch changes? I can't find it :C`
Offline forcefollow
Key mapping
« Reply #10 on: Thu, 02 February 2012, 06:11:34 »
ahaha..my mistake.. no wonder I got confused when I first try the switch I must've gotten myself the wrong manual...sorry
EDIT: look into the manual and read the dip switch setting in reverse order ,e.g., dip switch 4 to 1, 3 to 2 ...
the link is on my post above
Offline 443330
Key mapping
« Reply #11 on: Thu, 02 February 2012, 06:13:31 »
Thanks guys :)
Offline 443330
Key mapping
« Reply #12 on: Thu, 02 February 2012, 06:15:03 »
What's the difference between Switch 1 and Switch 4? :o
Offline 443330
Key mapping
« Reply #13 on: Thu, 02 February 2012, 06:28:27 »
Awesome, switch no1 does exactly what I wanted. Cheers.
Offline IvanIvanovich
  • Mr. Silk Underwear
Key mapping
« Reply #14 on: Thu, 02 February 2012, 11:53:43 »
Dipswitch 4 disable win left.
Dipswitch 3 make right win key an alt / altgr.
Dipswitch 2 switch caps lock and left control.
Dipswitch 1 make win left to fn left
Key mapping
« Reply #15 on: Thu, 02 February 2012, 12:20:01 »
Key Tweak works pretty well most of the time, although you have to restart to get it to take effect.
There is also a reset to original that puts it all back, if you want or need that.
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
