Author Topic: What mechanical keyboard for first time buyer?  (Read 2948 times)
Offline Babattaja
« on: Thu, 02 February 2012, 12:57:54 »
Hello, I'm first time buyer and i am not sure witch one to get. I mainly use  my keyboard for typing/Gaming (For Gaming FPS, Hack and slash, Sandbox games, RPG and some MMO) maybe 50/50 and i don't want loud keyboard. Maybe the brown one is best for me?
Let me know your thoughts and ideas.
Thank you.
« Last Edit: Thu, 02 February 2012, 13:03:30 by Babattaja »
Offline telepete
  • Jedi Knight and friend of Captain Solo.
« Reply #1 on: Thu, 02 February 2012, 13:09:02 »
Recently the CM storms seem to be on sale all over. I got mine for $65. It has blue switches but when I play games thats what I use. Click, click, click.
Sent from my LT15a using Tapatalk
Don't you wish Carnifex was at your side?
Offline Babattaja
« Reply #2 on: Thu, 02 February 2012, 13:22:02 »
Quote from: telepete;506476
Yeah CM Storm's are cool but nobody sells them here.. And i feel Filcos are great but i want hear opinions from swich color/type and keyboards before buying.
Offline daerid
    • Rossipedia
« Reply #3 on: Thu, 02 February 2012, 16:47:30 »
For best all around switch, I'd suggest Cherry MX Browns. For typing/gaming etc. Not as loud as blues, but still tactile (unlike reds/blacks). If you don't need a tenkeyless board, I'd suggest getting a WASD Semi Custom keyboard. If you need a tenkeyless, against my better judgement I'd have to say you should get a Leopold FC200R from Elite Keyboards. I personally don't like the Cherry-style stabilizers, however, you may not be bothered by them.
Where are you located?
Offline marvin737
« Reply #4 on: Thu, 02 February 2012, 21:12:20 »
Browns are usually the safest choice to start out with if you don't like the clicks noises of the blue. Its also one of the most popular switches that pro gamers use.
Offline Tony
« Reply #5 on: Thu, 02 February 2012, 21:39:16 »
Noppoo, Filco, Ducky, Rosewill or WASD with brown switches for the first mech keyboard.
Offline SOGOR
« Reply #6 on: Thu, 02 February 2012, 22:02:20 »
Or you can go mad like me and order 7bit phantom as the first.
Offline biolaser
« Reply #7 on: Thu, 02 February 2012, 22:38:53 »
Quote from: SOGOR;506943
That's a bold move..and an awesome one!
I would agree with most here that a keyboard with mx brown switches might be a good choice. Feedback without the click.
Choc Mini, QFR, Poker (MX Red) | Realforce 86U(v), 91UBK(v), 103UB(55) | AT101W | ABS M1 | Blue MJ2 (MX Brown) | Das Pro S (MX Blue)
Offline daniel0731ex
« Reply #8 on: Thu, 02 February 2012, 23:09:54 »
Blue, for easy and quick addiction. Then the OP will start to buy other boards.
"I hated the Blackwidow. Hated, hated, hated, hated, hated the Blackwidow. Hated it. Hated every cheapening feeble useless user-insulting gimmicks of it. Hated the keycap font that thought anyone would like it. Hated the marketing pretense to the keyboard by its belief that anyone would be impressed by it."
Roger Exbert - The Number One Keyboard Critic On The Planet.
Offline jc1104
« Reply #9 on: Mon, 06 February 2012, 20:13:03 »
Quote from: daniel0731ex;507010
So very true (unless noise is an issue, then the browns will be just as addictive)
