Author Topic: Goldtouch split ergonomic board  (Read 4117 times)
Offline ed_avis
« on: Tue, 07 February 2012, 08:45:38 »
fossala
  •  Guest
« Reply #1 on: Tue, 07 February 2012, 08:48:16 »
Rubber dome, I have heard it is quite good though.
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Tue, 07 February 2012, 13:27:48 »
Very quiet boards.  You can get one for less if you're patient.  The white ones tend to have yellow handles - making the black ones easier to sell on later.
Offline hoggy
« Reply #3 on: Tue, 07 February 2012, 13:40:13 »
I'm on my third.  Must stop lending them out.
fossala
  •  Guest
« Reply #4 on: Tue, 07 February 2012, 13:42:01 »
It was the board I was going to pick up before I stumbled on GH.
Offline Jim66
« Reply #5 on: Tue, 07 February 2012, 15:10:10 »
Poorman's G80-5000...
Offline hoggy
« Reply #6 on: Tue, 07 February 2012, 16:29:24 »
Spotted that on your desk.
Not jealous or anything...
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #7 on: Tue, 07 February 2012, 22:44:47 »
I used one of these at work before becoming addicted to this place.  They are very nice to type on, and great ergonomically.  A great example of a quality rubber dome.
Offline Jim66
« Reply #8 on: Wed, 08 February 2012, 02:59:51 »
Quote from: hoggy;508578
Don't be that jealous, technically the ISO model is still the poorman's 5000.
It spends its time back in the box. The ISO enter offends my eyes.
Offline hoggy
« Reply #9 on: Wed, 08 February 2012, 12:30:55 »
I don't mind ISO that much, but I do go that bit further to buy ANSI.  For programmers the enter key is such an improvement.
Offline ed_avis
« Reply #10 on: Wed, 08 February 2012, 13:00:23 »
It depends on what you're used to.  As a longtime ISO-er I find the one-row Enter key on ANSI layouts an annoyance - I keep hitting backslash instead (and there is no need for such a large-sized key to be allocated to a relatively infrequent character such as backslash).  The layout seen on some older boards has the best of both worlds - the Enter key both fat *and* tall.  Short+fat or tall+skinny are both a bit inadequate.
Offline DesktopJinx
« Reply #11 on: Thu, 09 February 2012, 16:29:24 »
The Goldtouch is decent for a rubber dome. I like the Kinesis Freestyle better -- it's also rubber dome but has a lighter touch. Of course the Goldtouch locks into place and is infinitely adjustable within its range; the Freestyle with the V3 or VIP option only has three specific angles. (Good enough for most.)
M15 for life
« Reply #12 on: Thu, 09 February 2012, 17:49:29 »
There is an older version and a newer. The newer can be spotted as having a row of nav keys to the right above the cursor keys. Hence, the one in the auction pic is an older version.
The newer version supposedly has lighter keys than the old. I find the old one to be relatively noisy -- but only when a key bottoms up.
Offline sordna
« Reply #13 on: Thu, 09 February 2012, 18:38:25 »
Good keyboard, I was using a Goldtouch for a long time before I settled on Kinesis Contoured / Advantage.
Offline davkol
  •  Post Editing Timeout
Lorem Ipsum
« Reply #14 on: Sun, 19 February 2012, 11:48:55 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
« Last Edit: Wed, 04 July 2018, 04:16:56 by davkol »
