Author Topic: Does this keyboard exist?  (Read 1954 times)
Offline furry_angina
« on: Wed, 08 February 2012, 05:14:50 »
This will be my first mechanical keyboard, but this is not your typical 'which keyboard should i get' post.  I know exactly what I want, but I don't know if it exists and I was wondering if any of you more enlightened geekhackers can point me to the right direction of my perfect keyboard.
For use:
Coding - (10+ hrs/day)
Gaming RTS/MMO - (15 hrs/week)
In order of importance of features:
1) Tenkeyless ANSI layout like Filco/Leopold
2) 1-2 USB pass through/hub like Happy Hackers Pro2
3) Cherry Brown or Clear, or Topre switches
4) Modability for when I want Ergo Clears (can pop out switches vs soldering, etc)
5) Mac/PC compatible
6) Less than $300 USD
Thank you :)
« Last Edit: Wed, 08 February 2012, 06:50:37 by furry_angina »
HHKB2 w/ M705 Realforce 87UB w/ G9
Offline trievalot
« Reply #1 on: Wed, 08 February 2012, 05:17:18 »
i can see you are new
you will simply buy 15 keyboards that will each do some of your required function, unless you LEAVE NOW!
[SIGPIC]
« Reply #2 on: Wed, 08 February 2012, 05:20:56 »
It's too late for that... I've gone in the rabbit hole.
Offline trievalot
« Reply #3 on: Wed, 08 February 2012, 05:22:18 »
im so sorry. it  gets easier I'm told
love your avatar btw
[SIGPIC]
Offline trievalot
« Reply #4 on: Wed, 08 February 2012, 05:23:24 »
if you want mac, have you tried the matias tactile pro?
[SIGPIC]
« Reply #5 on: Wed, 08 February 2012, 05:30:19 »
Why can't they just make a White Filco with a USB hub, Clear switches, and PBT ninja keycaps ? WHY?!
Maybe I'll just settle for a Leopold Tenkeyless Tactile Force and get a USB hub with a bag of blank PBT's. I think I just answered my own question...or would ABS be good with clears... arggh.
And thanks :)
Offline byFd
« Reply #6 on: Wed, 08 February 2012, 05:33:59 »
you could mode a usb hub into an existing board :)
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline trievalot
« Reply #7 on: Wed, 08 February 2012, 05:34:11 »
hhkb changed my life
[SIGPIC]
« Reply #8 on: Wed, 08 February 2012, 05:35:29 »
Quote from: trievalot;509100
I develop on a Mac, but I'm on Windows for gaming.  I've seen that keyboard around and it reminds me of the old school iMac keyboards lol.  I really like the tenkeyless simplicity.  I really want the Leopold Clears, but EK says that it's not recommended for first time buyers.  I've tried blues/reds/browns/blacks, so by deduction, I know I'll prefer Clears.
« Reply #9 on: Wed, 08 February 2012, 05:37:08 »
Quote from: byFd;509108
Yeah I'm not that adept with modding small peripherals.  I'd probably just end up burning my fingers lol... a Doctor Who USB hub should do it.
Offline trievalot
« Reply #10 on: Wed, 08 February 2012, 05:37:33 »
tried topre?
[SIGPIC]
« Reply #11 on: Wed, 08 February 2012, 05:38:53 »
I was |----this----| close to springing for a HHKB last night, but noticed that the layout is 'missing' the windows key?  And no, I haven't tried Topre, but I'm 80% sure I'll like it.  I can just buy it to try it, and then sell it here if anything...
Offline trievalot
« Reply #12 on: Wed, 08 February 2012, 05:40:50 »
if you want to try the layout get a HHKB Lite, get on ebay for around $20
crap domes but gives you the idea
[SIGPIC]
Offline Tarkoon
« Reply #13 on: Wed, 08 February 2012, 05:41:59 »
A Phantom with selfmade case would fullfill all your wishes! =)
Mine will get an integrated (powered) USB hub...
Offline pyro
« Reply #14 on: Wed, 08 February 2012, 05:44:44 »
These are the windows keys: ♦
[ Attachment Invalid Or Does Not Exist ] 39713[/ATTACH]
Right next to the space bar.
Dont' buy a lite, they're crap.
« Reply #15 on: Wed, 08 February 2012, 06:06:55 »
I'm not entirely sure how the DIP switches work, but do you have to fiddle with them each time you change OS platforms, or is it auto once you set them?
Also, I think trievalot suggested the Lite for me to test drive the layout.
I feel like buying Topre before Cherry is sort of cheating... Is this a douche move? Please confirm.
« Last Edit: Wed, 08 February 2012, 06:28:53 by furry_angina »
Offline laffindude
« Reply #16 on: Wed, 08 February 2012, 06:50:33 »
If you only want the smaller size of tenkeyless, you can try a G80-1865.
Offline forcefollow
« Reply #17 on: Wed, 08 February 2012, 08:57:25 »
Quote from: furry_angina;509119
simply said, DIP switches configures your keyboard (unless you're referring to other electronics) at hardware level. In the topre keyboards, they configure which switches reads as which
and no, it's definitely NOT cheating to get topre prior to other kinds of switches.
It's all go back to your preference and taste. I have several realforces and a HHKB as well as almost all kinds of cherry mx's (minus the rarer ones they listed in wiki), yet I still found none exactly what I'd like to feel. Some are close enough, but not perfect.
Again, none are.. so the addiction begins :p
« Reply #18 on: Wed, 08 February 2012, 12:43:18 »
Quote from: forcefollow;509166
heheh I figured that much, but I'm not sure if it's annoying to have to flick the switches every time I change computers (which would be quite often).
I'm barely knee deep into this, and I already have 3 keyboards lined up that I want to get haha....
Offline boli
« Reply #19 on: Wed, 08 February 2012, 12:54:03 »
Quote from: furry_angina;509331
If all the dip switch does is swap Ctrl with Win/Command it's no problem, because you can easily swap them via software in one of your two OS. So my keyboard is set to Mac mode, because that's where I use it most. In Windows I used SharpKeys to swap Ctrl with Command, and that was it - works like a charm in both OS, no changes to dip switches or firmware mode needed.
Keyboard: Kinesis Ergo Advantage (two LF editions with red Cherry switches, one regular with brown switches)
Keyboard layout: basically Colemak, with some remapping to end up with my custom Kinesis Advantage layout
Typing test profiles: typeracer.com / hi-games.net / keybr.com
Offline rustybarnacle
« Reply #20 on: Wed, 08 February 2012, 14:53:26 »
Quote from: furry_angina;509095
For use:
Thank you :)
Really, the only thing you're asking for that's a bit tricky is the USB ports.  If you can live without those, you have any number of choices.
« Reply #21 on: Wed, 08 February 2012, 20:01:37 »
Quote from: boli;509334
Thanks, this helps a lot!
Quote from: rustybarnacle;509385
Yes, precisely.  I'm waiting for my friend's HHKP to get here to see if I like it, then I shall purchase my own :)  Otherwise, I'm going Leopold Clears or Filco Browns.
Offline sordna
« Reply #22 on: Wed, 08 February 2012, 20:12:04 »
For use:
I think a Kinesis Advantage (retails at $269 with free shipping) fits the bill on all points except it does #4 partially (it's not trivial to swap switches or stems in the main keyboard area, but you can do it in the thumb area.) This board is generally very mod friendly and excellent for coding, in my experience.
