Author Topic: Help request: First time purchase  (Read 2132 times)
Offline Difesa
« on: Thu, 09 February 2012, 13:00:45 »
Hi GH!
I'm looking into buying my first mechanical keyboard.  I've lurked around a bit and done some googling and I think the best option for me is the WASD v1 with red switches and o-rings.  I've only ever used laptop keyboards and a logitech K120, and to be honest one of the few reasons I've decided to upgrade is because i spilled coke on the K120, otherwise I'm fairly content with it.  My question is whether or not there is something different I should be looking at; be it something with better features, better construction/ QC, better ergonomics, etc.  I went ahead and filled out the first time buyer sheet if that helps.
General Questions
1) What is your budget?
$200 USD
2) Where (country) will you be buying this keyboard and keyboard language layout?
USA, English QWERTY
3) Are there any brands that you prefer or any you don’t really like?
a.Like: -
b.Dislike: Razer
4) Would you consider keyboards that are used?
Near mint condition, sure
5) What are the primary tasks you will be performing with this keyboard?
Typing (prose, no programming), music recording/ production, and gaming
6) Will you be playing games on your keyboard? What type of games?
Yes.  An even spread of FPS, RTS, RPG, and MOBA
7) Would you prefer to see the keyboard you’re considering before purchasing it or buying a keyboard online without seeing it is OK?
Would like to see photos at least.
8) Will the keyboard be used for Windows, Mac, Linux, etc...?
Windows primarily with occasional Mac use
9) What other keyboard(s) have you used before and why are you not using it/them anymore?
Laptop keyboards (dell inspiron and macbook) and (currently) a Logitech K120 (spilled coke across the keys)
Build Quality and Design
10) What size keyboard would you prefer?
I would mildly prefer a tenkeyless, but it doesn't matter that much
11) Are the keyboard’s looks and stylishness important to you? If so, describe any physical features such as color, material appearance, etc...
I want as plain jane as i can get.  Maybe interchangable keycaps.
12) When are you buying the keyboard?
asap
13) How long do you want this keyboard to last?
As long as possible
Switch Questions
14) What key sound do you want?
Dont care
15) Do you want tactile feel?
no
16) Do you want clickiness?
no
17) How strong are your fingers?
Strong
Keyboard Components
18) PS/2 or USB
Either
19) Media keys? Macro Keys? Backlight? USB Hub?
None necessary
Customization
Interchangeable keycaps?
Offline whiskerBox
« Reply #1 on: Thu, 09 February 2012, 13:05:52 »
I would say a red mx or black mx leopold tkl from elitekeyboards
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Difesa
« Reply #2 on: Thu, 09 February 2012, 13:19:32 »
Ive read that the costar stabilizers that WASD uses are a lot better than the ones on the Leopold, or is that just a matter of preference?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Thu, 09 February 2012, 13:20:52 »
Stabilizer choice is primarily a preference.  If you are starting out there's a decent chance Cherry stabs won't bother you.  Costar stabs don't noticeably modify the feel of the keys they are used on, whereas Cherry stabs can change how the key bottoms.
Filco w/ Imsto thick PBT
fossala
  •  Guest
« Reply #4 on: Thu, 09 February 2012, 13:23:34 »
Quote from: Difesa;510335
Costar stabilizers don't change the feel of the switch. Cherry ones dampen the feeling of the switch, but I don't really notice unless I am trying to.
Offline Difesa
« Reply #5 on: Thu, 09 February 2012, 13:34:25 »
Leopold doesn't have a model with landing pads/ o-rings.  If I decided to disregard the TKL design factor, is there any reason i -shouldn't- buy a WASD?
Offline rknize
    • metaruss
« Reply #6 on: Thu, 09 February 2012, 15:59:11 »
You can put pads/rings on yourself.
Russ
Offline enoy21
« Reply #7 on: Fri, 10 February 2012, 10:23:34 »
Based on your Criteria:
For full size I would suggest a WASD Custom v1 in Black switches.  ( or red )  (Allows customization and every bit as good or better than Filco)
For a TKL I would suggest a Filco in Black from Amazon (Red switch is very hard to find)
For a TKL Red I would suggest a CMStorm Rapid Fire from PCHOME.
FYI , the tactile bump in browns are so slight as to be a great " all around" switch with a feeling of pressure between a black and a red.
Welcome to GH
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #8 on: Fri, 10 February 2012, 11:52:54 »
Red or Black Cherry MX switches.
CMStorm
Filco
Leopold
You have a big budget. Just go for the right switch and whatever board you like.
In general Filco is at the top of the chain.
Like some others, I would like to suggest to you Brown switches too. They are slightly tactile, and you may actually like them. Its very subtle tactility. I at first thought I'd be going for reds, but ended up getting browns because I liked the feel of them.
Welcome to GH.
Fight For Freedom. Stand with Hong Kongers
Offline Difesa
« Reply #9 on: Fri, 10 February 2012, 23:47:17 »
I went ahead and ordered the WASD with red switches.  I did think about the browns, however I tried some blues once and I absolutely hated them; while I know browns are extremely different, I figured I would go as far in the opposite direction from those I could.
At worst I'll resell and possibly try a Filco brown.
Will update when it comes in; I'm sure each of you wait with bated breath to hear how I like my keyboard.
Offline Tony
« Reply #10 on: Sat, 11 February 2012, 05:24:54 »
Filco/WASD red or brown will be your choice.
I am using a Filco brown and I like it very much. I heartily recommend it for a first purchase.
Offline Ovoxo
« Reply #11 on: Sat, 11 February 2012, 05:34:19 »
Quote from: enoy21;511013
Welcome to GH
You can purchase the CMStorm Rapid Fire w/ Red switches directly from CM Store now. $89.99 plus shipping.
