Author Topic: Which WYSE keyboards have MX switches?  (Read 3237 times)
Offline jellowiggler
« on: Thu, 09 February 2012, 16:21:33 »
Is there a model number guide for which models have MX switches / compatible key caps on them?
Is there nomenclature for which have injected molded keys like the Cherry boards all having H in the model name?
I'm going recycler and ebay diving.
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Thu, 09 February 2012, 16:47:13 »
All of them I have ever gotten with an RJ connector have MX, there are a couple hard to find ps/2 models that do, none with usb those are all domes. If it's doubleshots, it's MX and that is it more or less. Just take a puller with you if you have trouble telling doubleshots on sight. The yellow arrows give it away on 90% of them. It's still good to take a puller, if you want to focus on getting just the older ones with the thick caps when going to local recycler. Ebay will still be a crapshoot on thickness of caps.
Models I know for sure: Wy30-75, WY-PCE***.
« Last Edit: Thu, 09 February 2012, 16:51:57 by lysol »
