Author Topic: They call me the chopper  (Read 10008 times)
Offline o2dazone
« on: Thu, 09 February 2012, 18:34:06 »
Just need to modify the case, and I'm golden :) Arrow keys work similar to HHKB, replacing R_Function with R_Shift
[ Attachment Invalid Or Does Not Exist ] 39932[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 39933[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 39934[/ATTACH]
Offline o2dazone
« Reply #1 on: Thu, 09 February 2012, 18:35:08 »
btw the dyed keys were a biproduct of the rit dyeing test, didn't wanna go ruining nice topre keycaps :P
Offline byFd
« Reply #2 on: Fri, 10 February 2012, 03:08:35 »
go and mod fn keys between ctrl and alt :)
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline o2dazone
« Reply #3 on: Fri, 10 February 2012, 10:03:30 »
haha that would own, but I woud make R_Shift shorter and put Fn to the right of it. Just so its like my beloved HHKB
Offline o2dazone
« Reply #4 on: Sat, 11 February 2012, 18:27:52 »
Almost there...
[ Attachment Invalid Or Does Not Exist ] 40180[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 40181[/ATTACH]
Still need to get some epoxy putty and bond the edges, and then sand everything down. Unfortunately, there's going to be a very blatant seam, but that's ok.
« Last Edit: Sat, 11 February 2012, 18:34:59 by o2dazone »
Offline elbowglue
« Reply #5 on: Sun, 12 February 2012, 21:03:18 »
Awe.
Some.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline lootbag
« Reply #6 on: Sun, 12 February 2012, 21:18:37 »
bondo, sand and paint!
blatent seam gone.
but I understand if you do not wish to paint for aesthetic reasons.
Offline lightsout714
« Reply #7 on: Sun, 12 February 2012, 21:25:11 »
Dude that is bad ass. So is there no pcb? Almost looks like a ribbon cable or something.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #8 on: Sun, 12 February 2012, 21:34:04 »
Wicked, man.  You now own an SSSK.  Do you have plans for a function layer?
Offline whiskerBox
« Reply #9 on: Sun, 12 February 2012, 22:08:12 »
Hmm now I knew I would have use for that old model M in the closet. I can't wait to see it finished!
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline Ascaii
« Reply #10 on: Mon, 13 February 2012, 07:51:38 »
wow...looks clean and sleek. I like it!
Offline mekkanic
« Reply #11 on: Mon, 13 February 2012, 08:08:00 »
very nice ....
Offline o2dazone
« Reply #12 on: Mon, 13 February 2012, 09:21:19 »
Thanks guys
The epoxy putty was a huge failure. I obviously don't know how to use the stuff effectively, so I'll be using lots of C-clamps and regular epoxy. Something that dries translucent
Offline qwxc
« Reply #13 on: Mon, 13 February 2012, 09:35:46 »
That looks awsome, can't wait to see the final result!
Offline silent-circuit
« Reply #14 on: Tue, 14 February 2012, 07:50:39 »
So tempted to do this myself. Model M? Did you have to do a lot of soldering to get it working again, or just chop?
Offline o2dazone
« Reply #15 on: Tue, 14 February 2012, 07:51:43 »
Zero soldering. Just a bolt mod and cutting discs.
Offline o2dazone
« Reply #16 on: Tue, 14 February 2012, 13:22:56 »
I used 5 Minute Epoxy in this situation. I used epoxy putty on in the inside for additional bonding. Obviously I suck at lining up stuff, and I cut some lines really crooked when chopping up the frame. I didn't follow the 'measure twice cut once' rule, so I fixed what I screwed up with Epoxy putty lol. Altogether, the thing is great. I'm using AHK to emulate all my chopped off functionality, and it works surprisingly like the Poker mapped out like HHKB (RShift acting as the Function key). There is a very shallow function layer, just enough to cover the basics, arrow keys, delete, and a few others.
If anyone is going to do this project, a few things to consider:
-Get yourself a high powered rotary tool. I got a cheapo $8 job from Harbor Freight. And while it did what I wanted it to, I spent close to 3 hours chopping up the frame, and barrel plate.
-I used a carbide blade hack saw to chop the steel plate off. Also really cheap, but you don't need to splurge here. It does the job.
-MEASURE MEASURE MEASURE your cuts before making them. This applies to the barrel plate, steel plate and case (ESPECIALLY the case). If you mess up just a little bit, it can really show as you glue things back together. You can obviously sand out any unfitting areas, so you're given a bit of leeway, but it's like cutting paper, if you mess up slightly, you have to readjust, and then before you know it, there are wiggles and wobbles all over your cuts.
-Take your time
Offline o2dazone
« Reply #17 on: Tue, 14 February 2012, 15:41:51 »
I'd love to see some examples.
It's probably the first time I've ever glued plastic. At the end I was more like "**** it I just want it done" than actually completing it to look nice. Model M's are great, but the switch is definitely not for me. Unfortunately this keyboard will probably sit on my shelf for a while.
Offline neverused
Re: They call me the chopper
« Reply #18 on: Fri, 11 December 2015, 18:41:56 »
I've been looking at projects like this and see that the images are no longer viewable, any chance they still exist?
« Reply #19 on: Fri, 11 December 2015, 18:44:23 »
If you had waited two more months, it could have been a four year necro!
All the images were deleted when R00TW0RM hit.
Offline neverused
« Reply #20 on: Fri, 11 December 2015, 18:47:53 »
Yes but the question is specific to this thread and the OP was last active a couple weeks ago so I'm ok necro bumping it.
