Author Topic: Possible to mod filco mj2 tkl?  (Read 2025 times)
Offline f4d3
« on: Thu, 09 February 2012, 20:57:29 »
I have a filco mj2 tkl with black switches and a ducky 1008 with red switches. I was wondering if I can swap the keys between the 2 boards.
Offline pitashen
« Reply #1 on: Thu, 09 February 2012, 21:37:22 »
Sure, get urself a soldering kit and u r good t go
Offline f4d3
« Reply #2 on: Thu, 09 February 2012, 21:52:02 »
Any guide?
« Reply #3 on: Thu, 09 February 2012, 22:18:18 »
Offline byFd
« Reply #4 on: Fri, 10 February 2012, 02:47:47 »
wait wait, swap the keys or the switches?
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline f4d3
« Reply #5 on: Fri, 10 February 2012, 06:01:03 »
Switches.
Offline byFd
« Reply #6 on: Fri, 10 February 2012, 07:03:11 »
ok, then listen to the other guys :D
was just confused because you wrote keys in the OP :D
KBC Poker X MX Reds
Offline wuBu
« Reply #7 on: Fri, 10 February 2012, 11:12:33 »
Do you really need to desolder? can't you just pop open the switches and replace the insides? or does that not work like I imagine it to..
« Reply #8 on: Fri, 10 February 2012, 13:43:25 »
U can't, because it's plate mounted.
If it was pcb mounted it wouldn't be a problem.
