Author Topic: Android vs Windows Phone vs iOS?  (Read 7347 times)
Offline FinancialWar
« on: Fri, 10 February 2012, 01:12:10 »
what is your favourite mobile OS?
Offline zirb
« Reply #1 on: Fri, 10 February 2012, 03:02:28 »
For me it's Android. I have a Motorola Defy and I'm pretty happy with how much you can customize everything even without flashing custom firmware.
« Reply #2 on: Fri, 10 February 2012, 04:18:30 »
Android for me too.
Offline Ekaros
« Reply #3 on: Fri, 10 February 2012, 04:48:14 »
Symbian... ;D
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline byFd
« Reply #4 on: Fri, 10 February 2012, 04:52:51 »
well i got an android phone, but for me any phone where i can phone and text message would be fine :D
in the beginning i was like woah, smartphone, can do all the things! but now i just use it to phone and text. lol
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline mbc
  • -delete-
« Reply #5 on: Fri, 10 February 2012, 04:53:27 »
WebOS
Offline davkol
  •  Post Editing Timeout
Lorem Ipsum
« Reply #6 on: Fri, 10 February 2012, 06:10:12 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
« Last Edit: Wed, 04 July 2018, 04:13:52 by davkol »
Offline PixelVandalism
    • YouTube
« Reply #7 on: Fri, 10 February 2012, 06:24:05 »
I <3 Android.
Offline canthonytucci
« Reply #8 on: Fri, 10 February 2012, 06:37:26 »
iOS dev and user here. I've owned nearly a dozen android phones and used every version since 1.6 (and still have my nexus one) but keep coming back to the iPhone. Android ics is great, but the iPhone 4S camera and iOS smoothness has won me over again.   I've used windows phone 7 for a while as well and have nothing but good to say about it, if they had some nicer hardware And a few more of my favorite apps, I'd consider one as my daily.
« Last Edit: Fri, 10 February 2012, 06:40:04 by canthonytucci »
[SIGPIC][/SIGPIC]
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #9 on: Fri, 10 February 2012, 06:54:45 »
Android. I'm am very opposed to apple products in general (cept the iPod. that was pretty good design there). Android looks nice and gives me the flexibility I need as more of a power user. I had a older windows phone and It was really bad compared to the android. It's really damaged windows reputation in terms of mobile OS.
Fight For Freedom. Stand with Hong Kongers
Offline Vyr1s
« Reply #10 on: Fri, 10 February 2012, 08:55:55 »
Quote from: canthonytucci;510907
Not sure why you would quote HW in an OS/SW comparison...
Personally Android is the way to go for me.
Easy development, tons of support, streamlined without bloatware, and completely open.
A roomate has a WP7, and it is a slick interface/OS, but it seems that APPs aren't there just yet.
Offline bender1077
« Reply #11 on: Fri, 10 February 2012, 09:56:08 »
I like to tinker and break things, so Android is the best choice for me.  Script Manager is a fantastic (FREE) app that I use after any ROM update to get my evo set up the way I like it in no time.
Offline Wildcard
  • When caffeine isn't enough
« Reply #12 on: Fri, 10 February 2012, 11:01:48 »
I prefer the smoothness of iOS. I like to tinker, mod, and root, but when it comes to my mobile device I just want something that works fast and works well. The iPhone 4s has a good relationship between hardware and software and it just works.
Offline telepete
  • Jedi Knight and friend of Captain Solo.
« Reply #13 on: Fri, 10 February 2012, 11:16:15 »
iTunes is a brutal painful experience for me. Got my Android and I'm back to Amarok. Couldn't be happier. Android = Win.
Don't you wish Carnifex was at your side?
« Reply #14 on: Fri, 10 February 2012, 11:43:23 »
Quote from: Vyr1s;510946
I mention it mostly because I can't get the hardware I want with an android phone. I've used a variety of them, and none I've tried came close to the iPhone 4 build quality. There is a lot to love about android, but my preferences for hardware don't jive with what is available right now.
EDIT:
For the record, the iPhone is not my ideal either, but as close as I have found. After using an XperiaX10 (awesome camera there as well) and the Nexus S (which I have bought and sold twice now) I really do prefer a 4 inch screen, I've found anything bigger to be "too big" and anything smaller a bit too hard to type on. I'd also consider a portrait qwerty phone, (I've had a few blackberries and a nokia E71 which I have loved) but no one seems to want to make one that's any good and GSM.
EDIT2:
I have the same feeling about WP7, the applications are not getting the attention they need from developers. Most of the big names were there, Netflix, evernote, shazzam(i think) and rdio, but the applications themselves were not up to the standard of the Android/iOS versions.
« Last Edit: Fri, 10 February 2012, 11:53:53 by canthonytucci »
[SIGPIC][/SIGPIC]
« Reply #15 on: Fri, 10 February 2012, 11:44:43 »
Quote from: telepete;511059
Since iOS 5 I have not opened iTunes once, and before that I only plugged in to do system updates. I am a streaming music user though, and use rdio/last.fm, so I never really had a need to.
[SIGPIC][/SIGPIC]
Offline Vyr1s
« Reply #16 on: Fri, 10 February 2012, 11:55:39 »
Yeah I haven't look at it as of late, but was a little upset when it didn't have certain APPs that aren't HUGE but aren't little either.
Anyone developed on WP7? How is it for rules and what not?
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #17 on: Fri, 10 February 2012, 12:06:58 »
I don't exactly agree about "Easy Development". It took me a while to get used to the android SDK. It's well documented, but its not very thorough on how things should be used. I've had so many many errors. But yeah I finally got my app up on market after quite some time of tinkering.
Offline Vyr1s
« Reply #18 on: Fri, 10 February 2012, 12:10:58 »
Quote from: hazeluff;511102
Fair enough, but with appinventor and some of the other tech, its more accessible for 'noobs'.
But I like most that it's here is the SDK/platform, go nuts!
Opposed to other SDK/platforms where there are so many conventions and strict rules.
BTW what APP did you release?!
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #19 on: Fri, 10 February 2012, 12:14:14 »
Quote from: Vyr1s;511105
https://market.android.com/details?id=com.haz.game.cubetimeattack&hl=en
A small minigame. I was building the engine up for a rhythm game, but haven't had the time to develop further. Also I was in the process of learning and implementing new graphics using OpenGL instead of the Views that android give.
Tho I guess the experience for developing wasn't too bad. I just nitpicked some stuff I didn't like with the SDK.
Offline sLeezy
« Reply #20 on: Fri, 10 February 2012, 12:16:05 »
iOS brah
Input Devices
Keyboard - PFU HHKB Pro 2 Esc WASD | Filco Majestouch Tenkeyless Esc WASD
Pointing Device - Logitech Performance MX
Offline Wildcard
« Reply #21 on: Fri, 10 February 2012, 14:19:37 »
I have my iTunes library stored over a network share and it works great (mirrored & backed up). I initially hated iTunes, but after making that change along with a few other config changes in iTunes (ie. copy all files added to my iTunes to my library, etc..), I like it a lot.
I also have my computer set to pull new images/videos from my iphone/ipad and place them into their own folders within my itunes directory. Just a simple sync every time.
Offline Wildcard
« Reply #22 on: Fri, 10 February 2012, 14:28:05 »
One final point, for iOS users who just use iCloud to backup their devices, remember, Apple's definition of a "backup" is not the typical definition of a full backup. I prefer a full local backup/sync with the option to store a copy of items in my iTunes library to my library. This way for example, a music folder gets moved or deleted and you have to do a full restore of an iOS device, you'll already have a copy in your library and you're covered.
Offline BiNiaRiS
« Reply #23 on: Fri, 10 February 2012, 16:58:55 »
You should try MIUI. Cleanest, fastest, and most stable rom I've ever used. Tons of features as well.
KMAC 2 w/ErgoClears
Offline pitashen
« Reply #24 on: Fri, 10 February 2012, 21:21:04 »
I think I would be fine with any of the platform as long as they provide the smoothness and stability that I need.
That being said, I do hope WebOS gets to grow more.
« Reply #25 on: Sat, 11 February 2012, 05:20:23 »
no webOS please, the mobile OS is already crowded enough.
Offline davkol
Lorem Ipsum
« Reply #26 on: Sat, 11 February 2012, 11:33:04 »
« Last Edit: Wed, 04 July 2018, 04:14:22 by davkol »
Offline evolveS
  • ಠ_ಠ
« Reply #27 on: Sat, 11 February 2012, 11:42:46 »
+1 for the Android camp.
What I like the most about Android is the customization. If you don't like something about your phone, just swap it with something else!
"money comes and goes, but doubleshots are forever"
-a petty thief
Offline kriminal
« Reply #28 on: Sat, 11 February 2012, 12:27:11 »
iOS - currently.. looking to get WP7, its interface is slick!!
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline sunyoyo
« Reply #29 on: Mon, 13 February 2012, 02:01:08 »
I am sorry for this question. For I also use Nokia 5230(Symbian 60V5).
Bad question.
« Reply #30 on: Mon, 13 February 2012, 02:04:23 »
Quote from: sunyoyo;513059
Bad question.
Lol people still symbian? It's not even a really smartphone OS
Offline davkol
Lorem Ipsum
« Reply #31 on: Mon, 13 February 2012, 04:38:28 »
« Last Edit: Wed, 04 July 2018, 04:14:47 by davkol »
Offline royalsego
« Reply #32 on: Mon, 13 February 2012, 08:10:19 »
currently android, but planning to jump ship for WP8 once phone specs start crawling into laptop/desktop territory
FILCOmj287REDmx █ LEOPOLD104v1.0REDmx █ FILCOmj2CAMO87BRNmx █ DUCKY87GRNalps
Offline Lanx
« Reply #33 on: Mon, 13 February 2012, 13:53:43 »
i have a droid, thinking about droid4, fiance has iphone4. like both, would probably favor iphone if not for the need for itunes, itunes makes the iphone unusable.
Offline Internetlad
« Reply #34 on: Wed, 15 February 2012, 22:32:33 »
sort of want WP7, but goddamn, the only one verizon has is the Trophy, which is like 2 years old.
"Beep . . . Beep . . . Beep" -Sputnik I
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #35 on: Wed, 15 February 2012, 22:49:10 »
Been using Android for about 7-8 months now. I'm a fan. Currently have ICS on my Nexus S 4G, and love it. Looking to get into development for it soon, as I already have a decent grounding in java.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Gabo
« Reply #36 on: Thu, 16 February 2012, 13:41:24 »
At the moment I am using an iPhone 4. But I hate it.... Well the product/phone itselfs is really nice, the quality and design is amazing.
BUT the f***ing software around is horrible. I got so much hate on iTunes. All the conformation, registration, sync and so on... Y I CANT EASILY put some new music on my smartphone from another pc >.<
In october I'll buy me an android. Looking forward to get the new Samsung Galaxy.
Ducky ONE 2 Mini white
Offline Lanx
« Reply #37 on: Fri, 17 February 2012, 01:30:59 »
like i said, itunes is pathetic, my fiance' and i were trying to figure out how to transfer songs with itunes. Now i'm a 20year+ computer user she's not computer shy and is an engineer, we gave up, or rather i gave up and she had to google for videos. Later i called my friend up who has to work with macs at work and he said, "just dumb yourself down, and you can use a mac, you can't use your brain".
Offline Amr0d
« Reply #38 on: Fri, 17 February 2012, 03:51:57 »
Using iPhones since the 3G and I started to love iTunes after that because its ****ing easy to handle. I can't understand how people cannot transfer their stuff to an iPhone. Its clicking on checkboxes only...
Filco MJ2 TKL browns | Race 75% LE reds | Phantom GH Edition soon™
HeatWare
Re: Android vs Windows Phone vs iOS?
« Reply #39 on: Thu, 13 February 2014, 22:23:37 »
Android 80% of world market.
Offline PointyFox
« Reply #40 on: Thu, 13 February 2014, 22:42:56 »
Android assumes the user is intelligent and lets them make their own decisions.
iOS assumes the user in inept and makes decisions for them.
Windows assumes the user is a hipster and gives them modern art instead of a smartphone.
« Reply #41 on: Thu, 13 February 2014, 23:08:55 »
WP = killer camera!
Offline CatNip :3
  • bouncy bouncy
« Reply #42 on: Fri, 14 February 2014, 02:35:51 »
WebOS! That OS was amazing. ×.×
I use Android on my Nexus 4 without Root. The camera and audio is really bothering me but I'll live. :)
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #43 on: Fri, 14 February 2014, 03:03:52 »
Android because it's more open.
iOS is a more polished experience but I can't stand it.
WebOS wasn't bad but it needed more apps and polish.
Windows seems to think that people don't like information density.
However, as of late, Google's been really taking the piss.
« Reply #44 on: Fri, 14 February 2014, 03:27:38 »
WebOS?? Excuse my ignorance, but I thought that OS died when HP discontinued their tablet. What modern smartphone use WebOS?
Offline GR3ND3L
« Reply #45 on: Fri, 14 February 2014, 03:39:27 »
Android!
Suffered through iOS for a few years and took a stab at Windows and just didn't enjoy it.
Currently waiting on my second Android phone to arrive in the mail.
Offline davkol
Lorem Ipsum
« Reply #46 on: Fri, 14 February 2014, 04:00:56 »
« Last Edit: Wed, 04 July 2018, 04:15:25 by davkol »
Offline heedpantsnow
  • Old enough to know better
« Reply #47 on: Fri, 14 February 2014, 15:04:53 »
iOS, but only because I've already invested so much in apps and stuff.
I'm very interested in WP8.1.  I freaking love Windows 8.  Once you get used to it you can do so much more than 7, especially since there's a whole new realm for hacking/tweaking.
I'm back.
