Author Topic: Mac users: Tired of Mac OS X's mouse acceleration curve?  (Read 4326 times)
Offline iindigo
« on: Fri, 10 February 2012, 15:40:58 »
http://macupdate.com/app/mac/41736/smooth-cursor
SmoothCursor is a little utility that allows you to customize the acceleration settings of your mouse or trackpad separately.
It provides you with a slider to adjust the acceleration curve to be negative, positive, or entirely disabled.
I don't use this myself, as I cannot feel any difference between Mac OS, Windows, and Linux as far as mousing is concerned, but figured some of the crowd here might appreciate it.
EDIT: Just to clarify, the program is not my creation. I ran across it when browsing MacUpdate.
« Last Edit: Sat, 11 February 2012, 17:40:58 by iindigo »
Offline kps
« Reply #1 on: Fri, 10 February 2012, 16:25:07 »
I've never had a problem with the OS X or X11 (or X10 or NeWS or SunTools or NeXTStep or Interlisp), but Windows' spastic pointer movement drives me crazy.
Offline pitashen
« Reply #2 on: Fri, 10 February 2012, 16:28:33 »
Thanks for sharing. However I do make sure I game under windows.
Offline boli
« Reply #3 on: Sat, 11 February 2012, 05:05:07 »
Thanks for the tip.
I've been using USB Overdrive for years, and always disabled acceleration. Sadly I think I'll have to switch to something else (probably ControllerMate, as I already have a licence), because USBO doesn't work with the Magic Trackpad, which I'd like to give a try.
Keyboard: Kinesis Ergo Advantage (two LF editions with red Cherry switches, one regular with brown switches)
Keyboard layout: basically Colemak, with some remapping to end up with my custom Kinesis Advantage layout
Typing test profiles: typeracer.com / hi-games.net / keybr.com
Offline Brodie337
« Reply #4 on: Sat, 11 February 2012, 05:58:17 »
OH HELL YES!
Pardon me if I spontaneously fellate you for allowing me to set the trackpad separately to my mouse.
