Author Topic: Failed Leopold Space-Bar.... (Not anymore it's not!)  (Read 8171 times)
Offline PixelVandalism
    • YouTube
« on: Sun, 12 February 2012, 00:52:14 »
I attempted to mod the space-bar that came with my keycap set from wasd.
[ Attachment Invalid Or Does Not Exist ] 40199[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40200[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40201[/ATTACH]
It looks like it should work, it holds onto the stabilizers perfectly.
But it gets stuck on the way back up, and feels sticky and rough when you push the sides down.
I realized after about an hour of filing, then checking it, and repeating, that I should have cut off the original stems before I stuck the new ones in.
It looks brown and dirty because of the rusty file
« Last Edit: Mon, 13 February 2012, 02:34:07 by PixelVandalism »
Offline BiNiaRiS
« Reply #1 on: Sun, 12 February 2012, 03:48:57 »
so cut/drill them out now?
KMAC 2 w/ErgoClears
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Sun, 12 February 2012, 03:50:43 »
Well that's not really "failed" yet, because all you have to do now is cut the original side stems off.
    • YouTube
« Reply #3 on: Sun, 12 February 2012, 07:03:16 »
Do you have any suggestions on how to do that without damaging the top surface of my spacebar?
« Reply #4 on: Sun, 12 February 2012, 11:15:01 »
I've never tried it, but clamp it in cloth and use a dremel (or be careful with a drill sideways)?
Offline BiNiaRiS
« Reply #5 on: Sun, 12 February 2012, 15:54:03 »
Quote from: PixelVandalism;512422
it's plastic. just use some wire cutters and start snipping away. or a dremel would work as well.
KMAC 2 w/ErgoClears
    • youtube
« Reply #6 on: Sun, 12 February 2012, 22:43:22 »
Use a small dremel bit to just shave off the original stems.
http://www.amazon.com/Dremel-9901-Tungsten-Carbide-Cutter/dp/B00004UDJJ/ref=sr_1_11?s=hi&ie=UTF8&qid=1329108147&sr=1-11
    • YouTube
« Reply #7 on: Sun, 12 February 2012, 22:59:58 »
Would something like this work? (the pink conical one)
[ Attachment Invalid Or Does Not Exist ] 40310[/ATTACH]
    • youtube
« Reply #8 on: Sun, 12 February 2012, 23:03:43 »
Yeah the ones with the pink heads will work, although those are more meant to carve styrofoam or other soft wood. It might wear faster on plastic, but since it's just a small amount, I think it should be ok. The heads with brown sandpaper looks too thick to fit in the spacebar crack.
Offline Awful
  • Don't Topre.
« Reply #9 on: Sun, 12 February 2012, 23:56:45 »
Just wanted to add, you've done a stellar job so far. Looks really clean!
I hate everything.
    • YouTube
« Reply #10 on: Mon, 13 February 2012, 00:36:38 »
Quote from: WhiteFireDragon;512967
I don't have the brown sandpaper heads, I was just using the that picture as an example.
I will try that later tonight.
Quote from: Awful;512994
Thanks, I felt like I hadn't used enough epoxy when I glued them in, after it dried I was pleasantly surprised with the result.
    • YouTube
« Reply #11 on: Mon, 13 February 2012, 00:43:41 »
Quote from: ripster;513014
I would have used a jig and the glue recommended in my Gallons of Glue thread.
http://geekhack.org/showthread.php?24783-The-HUFFington-Post-Gallons-of-Glue-MOAR-Keyboard-Science
But I'm a bit of a perfectionist.  It's a #1 thing.
I never said I didn't use a jig.
[ Attachment Invalid Or Does Not Exist ] 40318[/ATTACH]
Edit**
I've dremeled out the original stems from the spacebar.
It's still a little sticky and strange feeling compared to the original.
I'm not really sure what I should do now?
[ Attachment Invalid Or Does Not Exist ] 40321[/ATTACH]
Edit 2.0**
I put o-rings on the space-bar, and it has almost entirely fixed the problem, there is still a slight stick if I push it slowly, but I'm hoping that it will stop over time.
« Last Edit: Mon, 13 February 2012, 02:40:02 by PixelVandalism »
Offline VladeK
« Reply #12 on: Mon, 13 February 2012, 05:51:21 »
May be you should wait for it to dry then apply some decal inside that spacebar.
    • YouTube
« Reply #13 on: Mon, 13 February 2012, 06:05:55 »
Quote from: VladeK;513168
I don't know what you mean?
Offline VladeK
« Reply #14 on: Mon, 13 February 2012, 06:20:04 »
You said your spacebar is "slight stick". So I think a paper decal inside that keycap may help.
    • YouTube
« Reply #15 on: Mon, 13 February 2012, 06:31:55 »
Quote from: VladeK;513173
I don't mean sticky to the touch.
After a keypress it can have some difficulty coming back up, it feels sticky.
Offline Glukos
« Reply #16 on: Mon, 13 February 2012, 13:37:53 »
This IS vandalism. Indeed.
