Author Topic: Need confirmation: Is this a Cherry White switch?  (Read 3869 times)
Offline Kurk
« on: Sun, 12 February 2012, 11:05:23 »
Hi,
I need confirmation if this is indeed a Cherry MX White switch. At first I thought it would be a MX Clear but it clicks and needs quite some force to depress. Moreover, its stem consists of two parts, see attachments.
BTW, what's that little bumb next to the cross on the stem?
Cheers!
Offline DaemonRaccoon
« Reply #1 on: Sun, 12 February 2012, 11:21:01 »
Yep, that's a White, where'd you find it?
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline Human
« Reply #2 on: Sun, 12 February 2012, 11:28:30 »
Nope, it isn't the normal Cherry White/Clear we saw. It may be related to Cherry Blue(stiffer variant of Cherry Green?), having a clicky sound.
Also can't deny that it may be a vintage switch(just a guess) that probably EOL already.
Another thing to note is this switch should be stiffer than Cherry Blue(by take a look at the spring). Try to compare to see if it is the same one we saw in Cherry Black or Cherry White. If both aren't, then maybe they are using the same spring like Cherry Grey?
« Last Edit: Sun, 12 February 2012, 11:33:52 by Human »
« Reply #3 on: Sun, 12 February 2012, 11:43:41 »
Quote from: Human;512512
Huh? Clears and Whites are two different switches. Which reminds me that I've heard of new White switches with heavy springs.
Offline laffindude
« Reply #4 on: Sun, 12 February 2012, 11:44:24 »
Chinese calls the MX clear as whites. That's probably why he's confused.
Offline o2dazone
« Reply #5 on: Sun, 12 February 2012, 11:55:22 »
Huh, has the two piece stem (like blues/greens), but the spring of a Clear. Perhaps Cherry MX White = clear spring + blue stem?
Offline Kurk
« Reply #6 on: Mon, 13 February 2012, 11:24:10 »
Quote from: harrison;512553
stem looks identical to the blue/green stem, but that spring looks very similar to a black, which would make it more or less a green.
you might get a more technical response out of deskthroity.  where'd it come from?
I got them from "Conrad", an European online electronics store. It is actually sold as Cherry MX1A-A1NN which is the the correct part number for plate-mounted Cherry White switches without LED. Cherry switch wiki
fossala
  •  Guest
« Reply #7 on: Mon, 13 February 2012, 11:29:45 »
I have some on order from thekeyboardco.
Offline Human
« Reply #8 on: Mon, 13 February 2012, 11:34:40 »
Quote from: Kurrk;513289
I don't see them in the chart(last part of the page)? I don't find "A"(bolded above) in the list. The more common Cherry Clear should be with "C". Probably some EOL stuff?
I suggest you mass keeping some of them if it really are(EOL), as rare + vintage cherry stuffs having really nice price, LOL....
http://www.cherrycorp.com/english/switches/key/mx.htm
EDIT:
Ok, as stated by the person above, keyboarco also do had them. Here are more details.
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=944
As stated, it should be clicky.
« Last Edit: Mon, 13 February 2012, 11:43:34 by Human »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #9 on: Mon, 13 February 2012, 11:36:11 »
Quote from: Human;513293
That chart also doesn't have brown or red switches.  Cherry has ignored that page for a very long time.
Filco w/ Imsto thick PBT
Offline Kurk
« Reply #10 on: Mon, 13 February 2012, 11:36:31 »
I don't see them in the chart(last part of the page)? I don't find "A"(bolded above) in the list. Probably some EOL stuff? I suggest you mass keeping them if it do as rare + vintage cherry stuffs having really nice price, LOL....
Indeed, it's not on the official Cherry website. Hence my question.
Offline Kurk
« Reply #11 on: Mon, 13 February 2012, 13:17:30 »
Not at all. I will try to shoot some better pics at daylight. Will not happen before the weekend, though.
fossala
  •  Guest
« Reply #12 on: Thu, 16 February 2012, 01:54:30 »
I have got white switch from thekeyboardco. It feels like a heavy blue but is less clicky.
Offline keyboardlover
« Reply #13 on: Thu, 16 February 2012, 11:59:18 »
GLWP!
(Good Luck With Potato).
fossala
  •  Guest
« Reply #14 on: Thu, 16 February 2012, 12:42:48 »
Quote from: ripster;516076
I suspect that one is just your normal Cherry Clear.   At least that's what their specs indicate (although the pic is different).
http://deskthority.net/viewtopic.php?f=2&t=1966&p=34355#p34355
Can you RipOmeter it?
For some ****ing reason OTHER Deskthority members can say RipOmeter but I can't.
http://deskthority.net/viewtopic.php?f=2&t=1949&p=34440#p34440
I bought one of every switch of them including white and clear. I would ripometer it but it isn't attached to a pcb.
