Author Topic: Solidtek 6600 - weird construction flaw  (Read 2586 times)
Offline Stormwatch
« on: Tue, 14 February 2012, 05:22:51 »
I've bought a Solidtek 6600 recently, and for $40 I didn't expect anything too fancy. But this detail was a bit of a letdown:
As you see, the 'C' can't be pressed as deep as the others keys; it sounds different too. Now, it's technically not 'defective', it works fine, and it's still better than anything that I could get locally. Besides, international shipping would make a return more expensive than straight up buying another unit. Still, it's quite annoying to buy something and find it's a bit 'off' like that.
Offline Human
« Reply #1 on: Tue, 14 February 2012, 07:04:39 »
Get on with it, Ripster will call it McRip effect.
Besides, even something cost more than $100(razer BWU) also had such problem and no much ppl whine about it, so you better get use to it.
Offline byFd
« Reply #2 on: Tue, 14 February 2012, 07:19:52 »
is the cap sitting correct on the stem? what switches are on that board anyway?
maybe your middle finger is too short? [ Attachment Invalid Or Does Not Exist ] 40464[/ATTACH]
White Filco Majestouch 2 Tenkeyless MX Browns
White Noppoo Choc Mini MX Reds
KBC Poker X MX Reds
Offline Human
« Reply #3 on: Tue, 14 February 2012, 07:21:28 »
ooo you!!!
Offline Stormwatch
« Reply #4 on: Wed, 15 February 2012, 15:31:28 »
Quote from: byFd;514033
Supposedly, Alps simplified type I. No idea if the problem is the cap or the switch itself, tried to pull out the key but could't, so I gave up.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #5 on: Wed, 15 February 2012, 15:35:38 »
To the OP and others as a WARNING.
When I clicked on the photo (post #1) I got two popups and one of them was a large and live "adult" related one. NSFW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just a heads up!  =S
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline Stormwatch
« Reply #6 on: Wed, 15 February 2012, 17:00:44 »
>not using popup / ad blocker
>2012
Offline Stormwatch
« Reply #7 on: Thu, 23 February 2012, 02:08:30 »
Yay, fixed it. Managed to remove the cap, and there was this little bit of plastic inside that clearly should have been removed but was not.
As it was a freak case, and easily fixed, now I can say it is a pretty good keyboard, definitely worth the price.
