Author Topic: Brown filco switch sometimes registering twice  (Read 1382 times)
Offline Aardwolf
« on: Tue, 14 February 2012, 19:44:09 »
Hello,
When typing long texts on a keyboard with brown filco switches and N-key rollover of a bit more than a year old, the 'e' key sometimes registers twice.
It only started doing this recently. It happens around 1% of the time, so that means when typing several sentences, it will happen a few times.
Only the e does this, no others.
For some reason, it most often happens while typing words, when pressing the 'e' key itself many times in a row, it registers once each time.
Any idea what could be wrong and if there's a way to fix this?
Could the switch itself be faulty, or the wiring in the keyboard?
Offline Aardwolf
« Reply #1 on: Tue, 14 February 2012, 19:57:47 »
Due to lack of compressed air (Is that something that is available in cans in all US shops or something? Here it involves an expensive machine instead, AFAIK at least) I blew in it. I'll see tomorrow if that fixed it, time to sleep now. Thanks so far!
« Last Edit: Tue, 14 February 2012, 20:00:16 by Aardwolf »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Tue, 14 February 2012, 20:08:03 »
Quote from: Aardwolf;514644
Canned air is readily available in any office supply shop and most places that carry computer peripherals as well.  It's over-priced, but it does work for short bursts.
Filco w/ Imsto thick PBT
Offline Aardwolf
« Reply #3 on: Wed, 15 February 2012, 06:58:51 »
Could hoovering work? :)
Offline Rumudiez
« Reply #4 on: Wed, 15 February 2012, 14:36:30 »
interesting... thanks for the wiki link, don't recall seeing it back in my days of lurking~~
40% layout, anyone?
Offline shogrran
« Reply #5 on: Thu, 16 February 2012, 22:00:12 »
Or if it is a new board, have them replace it under warranty?
Quote from: alaricljs;514648
Not in everywhere. Depending on where you  are from.
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
Offline Aardwolf
« Reply #6 on: Mon, 20 February 2012, 05:14:39 »
One of the options mentioned in the linked thread, is to use Deoxit.
Are there equivalents to Deoxit that could also work? Does there exist a generic name of what type of product that is rather than a brand name?
Something that could be found in a typical tools shop in Europe?
