Author Topic: Context Menu Key purchase?  (Read 4485 times)
Offline ravage
« on: Wed, 15 February 2012, 00:51:55 »
So I picked up an Overclock.net branded ducky shine, and it turns out that the keyboard doesn't have a context menu key. One of their forum members suggested to install SharpKeys and that worked wonders. I was able to convert the right windows button to a context menu button. However, the button on the keyboard still shows as a Windows logo.
Does anyone know where I can buy either a context menu button or even better, a context menu button which would work with LED backlit?
Either would be fine I guess, though I couldn't find anywhere that sells LED backlit key caps.
Offline Glukos
« Reply #1 on: Wed, 15 February 2012, 08:34:42 »
Offline Glukos
« Reply #2 on: Wed, 15 February 2012, 08:43:14 »
Offline CaiSter21
« Reply #3 on: Wed, 15 February 2012, 16:14:02 »
this might be a bit off topic, but ive always wondered, wat does that button actually do?
Ducky Shine DK 9008S Red LED |Rosewill RK-9000BR
« Reply #4 on: Wed, 15 February 2012, 18:55:11 »
Press it and see :O
It brings up a context menu. It's application dependent, but I can use it as a right click. Sometimes, it'll bring you to the menu on top.
Basically, it's not really that useful of a key anymore. I don't think I'll have one on my phantom, instead making it a modifier/function key.
Offline CaiSter21
« Reply #5 on: Wed, 15 February 2012, 23:23:51 »
i dont have a context menu key on my keyboard. its replaced with a Fn key
« Reply #6 on: Wed, 15 February 2012, 23:51:53 »
Yeah, I couldn't try it in windows, because my CMstorm is the same way.
