Author Topic: FIXED: Two switches not working on Filco Majestouch (MX Blues)  (Read 2037 times)
Offline Fantus_Longhorn
« on: Wed, 15 February 2012, 16:14:16 »
I'm Hoping someone has a few more ideas on what to try.
Right, the '*' and '-' symbols on the numpad are not functioning. The switches themselves work (tested with a multimeter) and I've tested various solder points along the tracers to ensure signal is getting through. Initially, the tracer had been lifted due to overheating on a previous attempt at a fix so I've replaced these section with wire; still not working despite a signal going through.
So, what's left? Anyone got any ideas?
These are the only two keys with problems, every other key is fine and tests OK with AquaKey.
« Last Edit: Thu, 16 February 2012, 18:14:29 by Fantus_Longhorn »
Offline hazeluff
  • 光復香港
    • Hazeluff
« Reply #1 on: Wed, 15 February 2012, 19:26:46 »
Also vote that ripster is a potato:
http://geekhack.org/showthread.php?27020-Let-s-rate-ripster
Yeah, Ripster's thing pretty much covers it.
Fight For Freedom. Stand with Hong Kongers
« Reply #2 on: Thu, 16 February 2012, 04:14:11 »
I'll follow the tracer back to the controller tonight then and try shorting it. I'll also blast some air and switch-cleaner in, worth a shot.
Is there any possibility that it's the controller that's faulty?
« Reply #3 on: Thu, 16 February 2012, 11:25:32 »
Haven't had a chance to find out whether it does or doesn't work yet, either ;)
Still at work right now, I'll let you know how it goes once I've tried. Appreciate the suggestions though.
« Reply #4 on: Thu, 16 February 2012, 16:06:09 »
Right, I've got some life out of the minus key. Spamming it furiously gets a result 1 in 100. So, I'm going to strip the switches out and pull them apart. At worst, I'll have to buy two new switches and fit those instead.
Update: Fixed!
Was a combination of several things; lifted/broken tracers and the contacts inside one of the switches not making contact.
The two blades inside the housing were not making contact so I bent the contact out 90degrees and then bent it back. It presses against the plate fine now, just feels a little soft when used and doesn't make the 'click' sound any more. I'll replace the switch at some point but I'm not hugely fussed.
On top of that, both the '*' and '-' switches needed rewiring.
« Last Edit: Thu, 16 February 2012, 18:13:55 by Fantus_Longhorn »
