Author Topic: Mega Man dye subs?  (Read 6103 times)
Offline Nalif
Mega Man dye subs?
« on: Wed, 15 February 2012, 20:20:46 »
I saw some of the Southpark and Starcraft dye subs keycaps floating around, and started to wonder how possible something like this would be. I threw the mock-up together pretty quick...I'm not sure how well pixels would translate with dye sublimation. A few notes:
1) Some characters ( namely Mega Man ) don't fill up the cap as well as others. Everything here is kept to scale as they would appear in game with the exception of the E-tank and the 1-up.
2) All characters are standing  at the same height, so their feet would appear to be at "ground level" if they were lined up.
3) These graphics aren't necessarily using the correct pallet, I just did this as a quick mock-up
4) Some of these graphics have a lot of white in them, and may need some sort of "glow" put around them to help them pop a bit. Examples are given.
[ Attachment Invalid Or Does Not Exist ] 40698[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 40699[/ATTACH]
My original thought was to put the stage select portraits on caps, but it seems to me that since those graphics are perfectly square, it would be difficult to center, and if it were even slightly off, it would look terrible.
[ Attachment Invalid Or Does Not Exist ] 40700[/ATTACH]
Offline Gawkbasher
Mega Man dye subs?
« Reply #1 on: Wed, 15 February 2012, 20:23:13 »
See the Starcraft 2 League Keycap group buy for why this will never happen unless somebody does it through a shady company in China.
Or you could convince Capcom to license it.  Good luck!
Topre Realforce 87U 45g / Logitech G9x / Razer Scarab
KBC Poker X (Blue)
/ KBC Poker X (Red)
Offline Nalif
Mega Man dye subs?
« Reply #2 on: Wed, 15 February 2012, 20:25:35 »
Quote from: Gawkbasher;515669
...this will never happen unless somebody does it through a shady company in China...
That's how the Southpark and Starcraft dye subs happened, right?
Offline Reptile
Mega Man dye subs?
« Reply #3 on: Wed, 15 February 2012, 20:29:24 »
Screw SP for dye subs. imsto can do it no problem. those would look awesome and I would get a lot :high5:
He got me these ones.
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline hazeluff
  • 光復香港
    • Hazeluff
Mega Man dye subs?
« Reply #4 on: Wed, 15 February 2012, 20:29:59 »
Get it personally through imsto. It won't happen with SP.
Yes that is how the southpark and SC2 dyesubs were made.
Fight For Freedom. Stand with Hong Kongers
Offline Nalif
Mega Man dye subs?
« Reply #5 on: Wed, 15 February 2012, 20:33:00 »
I figured it was imsto that did those. I sent him an PM asking how well pixelated graphics like these would work with dye sub. Hopefully I'll hear back soon!
Offline hazeluff
  • 光復香港
    • Hazeluff
Mega Man dye subs?
« Reply #6 on: Wed, 15 February 2012, 20:36:38 »
Have a look at Ragnorock's Nyancaps. It is pixelated. The outcome isn't too bad. But that's done by SP.
Offline Reptile
Mega Man dye subs?
« Reply #7 on: Wed, 15 February 2012, 20:39:24 »
What about these?
He needs big pictures to do it. I gave him almost wallpaper size ones for most of mine.
Offline hazeluff
  • 光復香港
    • Hazeluff
Mega Man dye subs?
« Reply #8 on: Wed, 15 February 2012, 20:40:30 »
i gave him SVG. infinite resolution
Offline Nalif
Mega Man dye subs?
« Reply #9 on: Wed, 15 February 2012, 21:14:21 »
Quote from: Reptile;515690
What about these?
http://fc06.deviantart.net/fs71/i/2010/090/b/1/Mega_Man_2_by_Pertheseus.jpg
Those are neat, but lose the nostalgia feeling you get with the originals. Not only that, you run into the problem of those being ( mostly ) square graphics, so even if they're slightly off, they end up looking bad.
Resolution isn't a problem with the old graphics - the images can be up-scaled as much as needed and still look crisp. Here's the hard  hat enemy blown up, for instance. ( the re-sized thumb-nail will appear fuzzy, but if you click for full size, the pixels are crisp again ) I really think keeping the graphics their original pixelated selves would be for the best.
[ Attachment Invalid Or Does Not Exist ] 40702[/ATTACH]
