Author Topic: Adjusting the stem on a keycap.  (Read 758 times)
Offline dreamingftw
« on: Fri, 17 February 2012, 13:47:31 »
Is there any way to remove, without breaking, the stem on the cherrycorp step caps lock and moving it over just a bit so it fits my Filco? I was planning to superglue it or something if I was able to remove it. I was thinking maybe using pliers or something to break off the stem. Anyone try this? Thanks in advance.
