Author Topic: Nice G81-8000 with DS keycaps on eBay for $40  (Read 3585 times)
Offline Wildcard
  • When caffeine isn't enough
« on: Sat, 18 February 2012, 15:09:32 »
Saw this while searching through eBay. I've seen these go for less, but $40 isn't too bad to harvest caps off this board. The double-shot keycaps in this board look pretty sharp. (Typing on some now)
http://www.ebay.com/itm/CHERRY-G81-8000-G81-8000HPBUS-2-Wired-Keyboard-/320835729169?pt=PCA_Mice_Trackballs&hash=item4ab34cb711
Offline KylJoy
« Reply #1 on: Sat, 18 February 2012, 15:55:54 »
I grabbed it.  Seemed too good to pass on.
Offline BiNiaRiS
« Reply #2 on: Sat, 18 February 2012, 16:00:55 »
pretty sure that bottom row is gonna be offset stems so they won't work without modification. and that enter key on the numpad looks really screwed up.
KMAC 2 w/ErgoClears
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sat, 18 February 2012, 16:29:15 »
They are usually beat to all hell if they are used. Well none cheaper I can find at the moment, but here is a seller that has 31 MY8000HUBUS, so might be able to get one that is not that beat up maybe...
Heres some MY7910HPBUS for cheaper, but has the short 2 unit right shift...
« Last Edit: Sat, 18 February 2012, 16:31:33 by lysol »
Offline Wildcard
« Reply #5 on: Sat, 18 February 2012, 19:28:36 »
Quote from: dorkvader;518182
Here's a used lasered (I think) G80. Anyone know what switches these usually have...?
http://www.ebay.com/itm/Cherry-MultiBoard-G80-8113LRDUS-2-External-Touchpad-Keyboard-3-Track-MSR-/390390942846?pt=LH_DefaultDomain_0&hash=item5ae51d0c7e
G80-8113LRDUS-2
  Black PS/2 keyboard with 3-track magnetic stripe reader and touchpad. US 120 position key layout with 16 additional keys, two PS/2 connectors. MX gold crosspoint keyswitches (with laser etched keycaps), 59 programmable and 41 relegendable keys. Includes CHERRY Tools multifunctional configuration software and UPOS drivers.
I beleve these are browns.
Also, do the G84's have ABS keycaps?
Just checked my G84, yep ABS written on the bottom of the keycap
« Last Edit: Sat, 18 February 2012, 19:37:26 by RiffRaff »
Offline BiNiaRiS
« Reply #6 on: Sat, 18 February 2012, 19:28:47 »
http://www.ebay.com/itm/G84-4100-Cherry-compact-keyboard-PS2-connection-original-box-/200715111342?pt=PCA_Mice_Trackballs&hash=item2ebb8d8bae
that G80 is probably browns or clears.
some 4100s have dye subs, some are lasered, and some are pad printed.
KMAC 2 w/ErgoClears
Offline Wildcard
« Reply #7 on: Sat, 18 February 2012, 19:36:17 »
Quote from: pjpettis;518100
Hope you enjoy it! I really like the keycaps.
On my filco, I was able to get all the caps to fit with the exception of the capslock, and row 4 modifiers plus the spacebar.
