Author Topic: leopold clear to ergo clear. What do I need?  (Read 1752 times)
Offline MKB
« on: Sun, 19 February 2012, 02:51:43 »
leopold clear to ergo clear.  What do I need?  What is involved?
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
Offline Henry Allen Venture
« Reply #1 on: Sun, 19 February 2012, 04:07:09 »
You'll need some lighter springs. The easiest way to get those is to get some MX Red/Blue/Brown switches, either from another cheap used board or just buy them from WASD, and harvest the springs from them.
I haven't had a look inside my Leo, but as far as I know you'll also have to desolder the switches from yours in order to get the stems out and switch the springs over.
Current collection:
Filco Majestouch 104-Key, w/ MX Browns
IBM Model M 52G9700
Leopold FC200R, "white" w/ MX Clears
Ducky DK9008S \'Shining\', white backlit w/ MX Blues
Cherry G80-3494(LCYUS-2), w/ MX Reds for Portal Mod
Not mine, but I\'ve got access to:
Filco Majestouch Linear R Limited Edition, w/ MX Reds
Filco Majestouch 2 \'Ninja\' Tenkeyless, w/ MX Blues
Leopold FC500R, w/ MX Browns
Offline RiGS
« Reply #2 on: Sun, 19 February 2012, 06:31:57 »
Best to stay with regular clears. If you find that stiff, then try blues.
Offline MKB
« Reply #3 on: Sun, 19 February 2012, 09:36:41 »
I have been able to use the clears for one month now... I will keep them.  Thanks Rigs!
Current:
Past:
Fujitsu (peerless)
HHKB Pro 2 (Topre)
