Author Topic: Favorite Hack for clears?  (Read 1862 times)
Offline MKB
« on: Tue, 21 February 2012, 01:46:46 »
What is your favorite hack for clears?
________________________________
Current:
Leopold Tenkeyless (Cherry Clears)
Leopold Tenkeyless (Cherry Reds)
Filco Tenkeyless Zero (White Fukkas)
Unicomp SpaceSaver 104 (Buckling Spring)
Past:
IBM Model F (Buckling Spring)
IBM Model M (Buckling Spring)
Northgate (White Alps)
Fujitsu (peerless)
HHKB Pro 2 (Topre)
Deck Legend (Cherry Blacks)
Deck 82 (Cherry Blacks)
Unicomp Customizer 104 (Buckling Spring)
fossala
  •  Guest
« Reply #1 on: Tue, 21 February 2012, 01:54:40 »
Do you mean clear mod? As in ergo clears or panda clears?
Offline MKB
« Reply #2 on: Tue, 21 February 2012, 02:33:29 »
What mod improved your clear keyboard the most?
Current:
Past:
Fujitsu (peerless)
HHKB Pro 2 (Topre)
fossala
  •  Guest
« Reply #3 on: Tue, 21 February 2012, 02:36:23 »
I tried ergo clear (brown/blue/red spring) and panda clears (black spring). Ergo clears do not bounce up quick enough and panda clears are not worth the effort. If I was you I would just stick with normal clears but I am sure someone here will disagree with me.
Offline FKSSR
« Reply #4 on: Tue, 21 February 2012, 11:19:57 »
Quote from: fossala;520486
I was going to try Ergo Clears when I got a new set of Clear switches from a Group Buy.  However, it does concern me that they may not bounce up quickly.  The keyboard will be for my wife, and she touchtypes very quickly (as I do), and if there's a lag there, I feel that it may be better to just stick with regular clears.  I just thought they would be too stiff or hard to depress without doing the mod...especially for a woman with slender fingers. :P
Add me on Steam | Twitter
« Reply #5 on: Tue, 21 February 2012, 12:21:05 »
I prefer original clears, but I find that they feel a bit too frictiony. I am also afraid of wear, with all this friction.
I would like to get the sliders lubricated to reduce friction, and thus, wear. I have read several data sheets for lubrication liquids and none has been as good (on paper) as RO-59.
Therefore, I would like to get them lubricated with RO-59. That would be my "favourite" mod.
« Last Edit: Tue, 21 February 2012, 12:23:23 by Findecanor »
Offline jonnybastard
« Reply #6 on: Tue, 21 February 2012, 19:05:36 »
I just turned my poker with browns into ergo clears last night, just to try something different.  Early days yet but from the quick play I had I'm a fan.  I type around 100wpm and didn't notice any issues with key lag etc.
KMAC    -    HHKB Type-S    -    Filco TKL LineaR    -    Poker X    -    KBT Race LE
flickr
Offline FKSSR
« Reply #7 on: Wed, 22 February 2012, 11:28:24 »
Quote from: jonnybastard;521207
Good to hear...  I'm still nervous about trying the mod if it doesn't work or eventually the springs wear out and have a problem, though...  Hmm...
« Reply #8 on: Wed, 22 February 2012, 22:38:11 »
Quote from: FKSSR;521937
Just do it and if you don't like it then change them back, easy as!
flickr
