Author Topic: Do all MX Blues have the same loudness?  (Read 2135 times)
Offline WiL11o6
« on: Wed, 22 February 2012, 02:31:18 »
My Filco with blues came today and I am typing on it right now. Typing wise, it feels much better to type vs my Rosewill with reds. I have never tried blues and have only read about it being clicky, but this is pretty loud! It is 12:30am right now and all I hear is clickity clack. I was playing BF3 at first and again, all I could hear is the click and clack noise. Of course, since I am not used to it yet, I am putting 100% of my attention to the noise rather than playing the actual game or what not, but are all blues this clicky? Or is it just Filco blues are clickier.
Offline wompwomp
« Reply #1 on: Wed, 22 February 2012, 02:35:34 »
In theory, yes. Every MX blue switch itself should sound the same, but you must take into consideration keycaps, if PCB mounted or not, keyboard frame, and etc. All of these things effect the way the MX blues sound.
Offline spikeh
« Reply #2 on: Wed, 22 February 2012, 02:48:15 »
Depends on whether the switches are plate or PCB mounted I'd imagine. Age may also be a factor as the switches' plastic working parts wears down.
If you want it to be clicky (by being 100% focused on the clicking sound), it will be clicky. See placebo effect and confirmation bias.
Filco Majestouch 105 | IBM Model M SSK | Filco Majestouch 2 87
Offline shogrran
« Reply #3 on: Wed, 22 February 2012, 04:28:38 »
Well I think supposedly mx blues are mx blues, but that is just the switch itself.
I had the liberty of comparing the feel of using a cmstorm qfr - mxblues with a razer bw - mxblues. The feel and sound is different if you ask me. So the overall build of the board affects it in some way.
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
Offline Squelos
« Reply #4 on: Wed, 22 February 2012, 06:19:39 »
The keycaps change the sound of the keyboard.
I changed the keycaps of my BW, and the sound changed considerably. The keycaps on the BW are pretty fragile, and lightweight. you can break the stems quite easily.
Offline DalaiLameR
« Reply #5 on: Wed, 22 February 2012, 06:55:52 »
The sound of blues can be altered by changing the following variables:
- PCB or plate mounted
- keycaps (ABS, PBT, POM)
- o-rings
The sound of the switch itself is allways the same (we germans to know our craftsmanship !!!!)
For me the combination of plate mounting, PBTcaps and O-rings makes the perfect mx blue experience, but that is highly subjective
[SIGPIC][/SIGPIC]
Model M SSK ReAlforce 88UB 45g Filco MX Blue Filco MX Red
Offline limmy
« Reply #6 on: Wed, 22 February 2012, 07:04:28 »
If you use thick and heavy key caps, the sound coming from blues will be less resonant and have lower frequency. However, they will still click.
If you have 20 bucks to spend on caps, I would recommend trying Cherry POM keys sold at Signature plastics. The set is only for letter keys, however. I bought them for 10 plus shipping. POM keys are heavier than PBT keys and the particular POM keys are very thick.
http://www.keycapsdirect.com/key-capswhatsnew.php (It is the black set)
Also here are some typing videos of the Cherry blues with thick PBT caps. Leopold 700R is sold with thick PBT caps and some cherry blue users in KBDMania were not happy with the feel because the click sound was less noticeable compared to other boards.
FC700R - Cherry blues
http://www.youtube.com/watch?v=8reAkSgR2bk
http://www.youtube.com/watch?v=9uOpVBLMPd8
http://www.youtube.com/watch?v=PChAU-PuOXY (Yes, they are cherry blues!)
Since recording conditions and devices are different, I don't think it is accurate comparison, but if you compare the above videos with these, the latter are more high pitched.
http://www.youtube.com/watch?v=WdAE7pj4d90
http://www.youtube.com/watch?v=JggEpECGXn8
This is because heavier material produce lower frequency sound, and the order of specific gravity for materials used for keys are the following: ABShere, part of my English translation posted here)
As a final word, if you don't like clicky sound, I think it would be best if you trade with other non-click switches, as blues will still make clicky sound no matter what key caps you put on. If you want to experiment, I would recommend Cherry POM caps.
Edit: The POM keys are very slippery and F and J keys don't have nubs but is more curved. See "All about keys" wiki section 3.7 Nubbly, Nubby, Nubile, Nubian Nubs for more information.
« Last Edit: Wed, 22 February 2012, 07:27:45 by limmy »
Offline lowkey
« Reply #7 on: Wed, 22 February 2012, 07:16:42 »
^^ I bought a set of those POM keys and they were so slippery they felt like they were always covered in grease.  Couldn't stand them, they never felt "clean" to me :(
Offline jspark
« Reply #8 on: Wed, 22 February 2012, 08:00:19 »
I think it depends on plate, keycap and other materials.
You can simply imagine accoustic guitar.
KBC Poker X Cherry MX Black switch
Filco Majestouch2 Ninja Cherry MX Blue switch
IBM Model M 1391401 in 1988
Offline patrickgeekhack
« Reply #9 on: Thu, 23 February 2012, 07:50:08 »
I just pulled out my Das and currently typing on it. Keep in mind that what I am going to say is subjective, but subjective is important since everyone experiences things differently. Someone scale is different from someone else's scale even if both scales go from 1 to 10.
Anyway, the keys feel lighter and quieter on the Das than on my G80-3000. The first one is plate-mounted whereas the second is PCB-mounted. Interestingly, I found that this feeling also applies to brown Cherry in my case. My Filco keys feel lighter and quieter than the keys on my Compaq MX-11800. Again, the first is plate-mounted whereas the second is PCB-mounted.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
