Author Topic: Blackwidow keys staining/fading? Is this normal?  (Read 14230 times)
Offline Supertoaster
« on: Wed, 22 February 2012, 19:01:20 »
Besides the stiff backspace issue I had no problems until today where I looked at the keys and saw a few (mostly WASD because I game a lot) are fading/stained. But I've only owned the keyboard for about 2 months and have been trying really hard to keep it clean so that it doesn't end up like my old keyboard. I dust it every day with just a damp cloth on the keys and some windex on the glossy part. I've even been putting cocoa butter lotion on to make my fingers smoother so they don't fade as fast (heh)They seem to have black streaks. I can't take pictures because I don't have a good enough camera. Is there any way I can clean this without ruining the key or am I stuck?
thanks
« Last Edit: Wed, 22 February 2012, 19:08:05 by Supertoaster »
Offline Rumudiez
« Reply #1 on: Thu, 23 February 2012, 02:19:23 »
That's what happens to pad-printed ABS key caps. I'd say to look into buying a new set of PBT key caps, but I think the space bar on the BW isn't a standard size, not to mention you'll never be able to find replacements for your macro keys. At the least you shouldn't have any problems ordering a set of WASD caps from somewhere like EliteKeyboards or WASDKeyboards.
40% layout, anyone?
Offline Squelos
« Reply #2 on: Thu, 23 February 2012, 04:37:50 »
The BW isnt pad printed.
But yeah, as do all laser etched keys, they stain. I imagine they went kinda yellowish/cream color?
And the macro keys are just standard. R1,R2, R3,R4. But then they are kinda useless. The driver is too ****ty to do anything with them.
Offline Roguemaster8
« Reply #3 on: Thu, 23 February 2012, 04:49:41 »
Quote from: Squelos;522917
Now that's not very nice, I found them very useful for opening Chrome, Skype, and MS Paint.
I had a BW Ultimate for about 2 weeks and I noticed staining even then. I'll just suggest what others have, try to find some PBT key caps. Or go to WASD for some, well, WASD keys.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
Offline shogrran
« Reply #4 on: Thu, 23 February 2012, 08:48:22 »
Yes they fade quite quickly. Replacing the keycaps I think is going to be harder than with other keyboards. I think the height of those razer keys are not the same - but I may be wrong. Plus there is another thread here talking about compatibility issues with stabilizers.
Well that's razer for you, they always want to change things - sometimes its good sometimes its bad.
Razer Blackwidow Elite
CMStorm Quickfire Rapid
[SIGPIC][/SIGPIC]
« Reply #5 on: Thu, 23 February 2012, 14:04:12 »
Quote from: shogrran;523013
I  think they are a bit sunken into the keyboard itself more then others. Someone did put a new set of keys (only the letters) and did mention that they were just a bit taller but fit.
I'm probably going to order a set of White keycaps from WASD in the future if it gets much worse. Since the spacebar will not work will the Enter, Shift, Backspace, etc keys still fit? Do WASD keys wear out fast?
« Reply #6 on: Thu, 23 February 2012, 14:22:07 »
Quote from: Rumudiez;522858
The Macros are the same size as the other keys and the keys are laser etched (but the symbols below some of the keys are printed)
Is there anything I can do to make the keys work on the Black Widow so that one from WASD would fit on the Enter/Backspace/Shift keys.
The keys haven't really changed color. They just sort of have faint but noticable streaks of black running through the lettering (in a vertical direction?). I'll try to take pictures when I get home if my phone decides to work.
Does anyone have pictures of white keycaps on the blackwidow?
« Reply #7 on: Thu, 23 February 2012, 16:47:54 »
Quote from: harrison;523394
wrong.  The BW Ultimate isn't pad printed, but the normal (non-backlit) one is.
It looks like its laser etched to me. It looks a tiny bit blurry and feels rough.
Offline Rumudiez
« Reply #8 on: Thu, 23 February 2012, 17:40:21 »
He didn't say he had the Ultimate, though. Nonetheless, the $40 (or however much it is) doesn't justify the differences between the Ultimate and the regular imo.
If the BWs do follow standard row heights, then blank or custom print keys I suppose would work for the macros. Then it would just be weird to buy a set of one key out of each row without custom ordering them from WASD (I personally can't think of another retailer that would accommodate such an order).
Stack 'em up for reasons not to buy from Razer again...
40% layout, anyone?
« Reply #9 on: Thu, 23 February 2012, 17:44:51 »
Quote from: Rumudiez;523572
I have the standard blackwidow.
I was planning to order a set of white keycaps from WASD in the future (if this gets really bad)
« Last Edit: Thu, 23 February 2012, 17:51:59 by Supertoaster »
Offline Rumudiez
« Reply #10 on: Thu, 23 February 2012, 17:56:03 »
Trolling again? He was responding to another member, not the OP. That happens a lot in these forums... At least he was bringing in new information about the keyboard in question.
40% layout, anyone?
Offline lowkey
« Reply #11 on: Thu, 23 February 2012, 21:16:00 »
my quickfire isnt holding up too well either.  this is after a few weeks at most...
Offline himynameisbunny
« Reply #12 on: Thu, 23 February 2012, 22:21:26 »
Quote from: harrison;523864
there are absolutely pad printing on the legends on the set in my possession
Not trying to pick sides but mine were definitely laser. When I had it.
I've moved on to the dyesub master race.
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
Offline laffindude
« Reply #13 on: Thu, 23 February 2012, 22:47:24 »
Now I've seen everything. People calling each other names over keycap legend.
« Reply #14 on: Thu, 23 February 2012, 23:36:47 »
I thought mechanical keyboards brought peace and harmony to the world?! :Cry:
On topic:
Is there any way I can clean it or is it stuck like this?
« Last Edit: Thu, 23 February 2012, 23:38:48 by Supertoaster »
Offline laffindude
« Reply #15 on: Fri, 24 February 2012, 00:29:13 »
Try some isopropyl alcohol.
« Reply #16 on: Fri, 24 February 2012, 00:33:18 »
Quote from: laffindude;524005
Will 51% do or should I try stronger?
« Reply #17 on: Fri, 24 February 2012, 15:49:35 »
BONUS: I got a picture!
[ Attachment Invalid Or Does Not Exist ] 41616[/ATTACH]
Will WASD keysets work on the BlackWidow?
Offline shogrran
« Reply #18 on: Fri, 24 February 2012, 15:59:09 »
Is it just me or is the letters whether pad or laser etched on rubber dome keyboards better quality than mechanical?
I have had an arctosa and several cheap rubber domes and never had a problem with fading of the letters.
[SIGPIC][/SIGPIC]
Offline brkim1324
« Reply #19 on: Fri, 24 February 2012, 15:59:53 »
Quote from: ripster;524311
I'd go straight to 99% and even THEN you have a 50/50 chance of it working.
Everything.  And I mean EVERYTHING is documented here:
http://geekhack.org/showwiki.php?title=Das+S+Lasered+Keys+Versus+Filco+Pad+Printed+-+FIGHT
Boy that noob that accused me of being a troll is an *******.  Should ban that ****er.
LOL I love you Ripster. You are funny man... or are you?
But yea, I think it's Laser too.
« Reply #20 on: Fri, 24 February 2012, 16:11:06 »
Quote from: shogrran;524606
Mc Rip effect?
« Reply #21 on: Fri, 24 February 2012, 19:04:50 »
Does it look more faded or stained? It doesn't look brown at all to me, just darker.
Offline Rumudiez
« Reply #22 on: Sat, 25 February 2012, 00:46:20 »
Oh, I've just been chuckling to myself as I occasionally check this thread. You see, you misinterpreted what I meant in my second post, but only to your loss did it affect anyone. I think most of the second page of this thread is hilarious xD
40% layout, anyone?
