Author Topic: difference between Ninja and Normal Filco Keyboards?  (Read 1928 times)
Offline Av180
« on: Fri, 24 February 2012, 17:24:31 »
Is ninja the brown instead of the blue?
Because on Amazon it says there are the clicky version ninja and normal majestouch keyboards?
I want brown. :p
KMAC 62g Clear
Poker 2 Stock Red
Leopold FC200RE Stock Clear
Offline naranja
« Reply #1 on: Fri, 24 February 2012, 17:26:53 »
ninja is just the design of the keyboard and does not actually address what type of switch it is. You'd just want a brown ninja(tactile). (the clicky ninja has blue switches.)
Offline HaiiYaa
« Reply #2 on: Fri, 24 February 2012, 17:27:21 »
On keyboardco I believe they only have the version with cherry mx brown switches, but I know you can get other versions also from other places
Offline Av180
KMAC 62g Clear
Poker 2 Stock Red
Offline HaiiYaa
« Reply #4 on: Fri, 24 February 2012, 17:42:56 »
Quote from: Av180;524681
this would be brown?
http://www.amazon.com/Majestouch-2-Tactile-Action-Keyboard-FKBN104M/dp/B0060J3VCE/ref=sr_1_37?ie=UTF8&qid=1330126627&sr=8-37
Thats not the ninja
But yes tactile = cherry brown
click action = cherry blue
linear action = cherry black
Offline luma
« Reply #5 on: Fri, 24 February 2012, 19:45:01 »
The Ninja's have side-printed keys.
edit: also all the black cased Filcos with Cherry browns have been out of stock on amazon for the last week.  Waiting to get one myself.
