Author Topic: LF 104 PBT Blue Blank Keycaps  (Read 3688 times)
Offline life617
« on: Fri, 24 February 2012, 21:44:40 »
I was wondering if anyone can help me locate a place to buy a 104 PBT Blue Blank Key Cap set for my Filco Majestouch Ninja 2 with Cherry MX-Blue switches?
« Reply #1 on: Sat, 25 February 2012, 17:20:38 »
No such thing
Offline Human
« Reply #2 on: Sat, 25 February 2012, 21:25:34 »
You can try contact Qtan(a member here) to ask if he got such option for you.
Even in taobao, your request are also very rare(the easiest I can think of is dying full-set white PBT to blue). Possible but not probable.
Offline WhiteFireDragon
    • youtube
« Reply #3 on: Sun, 26 February 2012, 00:30:35 »
The only PBT blanks that are available is white. No other colors available. You might be able to get a set from SP, but they'll charge you up the bum for it, and also only a ABS spacebar. It's at least $1 per PBT cap. If you're desperate to get blue, then try RIT dye.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #4 on: Sun, 26 February 2012, 12:10:01 »
i recently bought some pbt caps from SP's stock, and it was 1$/cap, i could only choose from the caps that are listed on their stock page (dated at 1/2/12), and melissa could only give me grainy phone cam photos of the caps before i bought. i only bought a few caps, so that was fine, but if you're trying to assemble a full set i wouldn't recommend it.
Offline DragonLotus
« Reply #5 on: Sun, 26 February 2012, 18:39:39 »
Round 4 DS replacement says that it has PBT Standard Blue Blank key caps.
http://deskthority.net/wiki/Round4_Pricelist#BLANKPBT_.28Blank_cylindrical_PBT_style.29
BLANKPBT/BLANKSTD/BLUE
Very pricey though. And I have no idea which blue they are using.
