Author Topic: [COMPLETED!] WYSE Moogle Kits!  (Read 132273 times)
Offline 7bit
  • MX1A-G1DW
[SHIPPING DELAYED] WYSE Moogle Kits!
« Reply #350 on: Fri, 13 April 2012, 15:28:15 »
Quote from: Quarzac;545126
I think for the color codes GE and BFU look to be the closest to me.
GE is the wrong color. It is toooo dark.
If you want to match new key caps with old ones, just put them in the sun until they look like the rest.
 I will get the color samples tomorrow and try to find the closest match. Also, I've asked Melissa if they keep records of which colors had been used.
update:
... too many years ago and those record have been destroyed.
Sorry I don't have any specific color information for you!
Waaaaaaaahhh!!!!!!!!
« Last Edit: Fri, 13 April 2012, 15:32:21 by 7bit »
Buy key caps here: Round 5
Buy switches here: CherryMX
« Reply #351 on: Fri, 13 April 2012, 15:31:35 »
Quote from: Denonic;556935
GBA for spacebar, BBI for legends, and for dark grey I'm going to throw a vote towards GSY.
I thought we were going with these colors?
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #352 on: Fri, 13 April 2012, 15:40:12 »
Denonic's most recent one is the new go for. 7bit, it would be much appreciated if you could take a look.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline 7bit
  • MX1A-G1DW
« Reply #353 on: Fri, 13 April 2012, 16:17:08 »
Quote from: jdcarpe;574823
I did only read half way through. Sorry.
However, I'm quite sure not all colors will match. I'll take a look into this tomorrow.
Offline Quarzac
  • A very busy dude!
« Reply #354 on: Fri, 13 April 2012, 21:14:59 »
Just for the record, you guys have until the 22nd to pay. If you do not pay by then, your order will be dropped. Sorry for the long timetable, but I'm outta town from the 15th to the 22nd, and probably won't have too much access to computers.
Offline Denonic
« Reply #355 on: Mon, 16 April 2012, 16:35:50 »
What happened to 7bits posts with properly matched colors? As well as every other post after this?
Offline sth
  • 2 girls 1 cuprubber
« Reply #356 on: Mon, 16 April 2012, 16:38:16 »
Forum rollback...
Offline 7bit
  • MX1A-G1DW
« Reply #357 on: Mon, 16 April 2012, 16:40:07 »
Quote from: Denonic;576343
Eaten up by little monsters who think bits and bytes are good food.
Here it comes again: (the content)
Offline Denonic
« Reply #358 on: Mon, 16 April 2012, 18:10:56 »
Quote from: 7bit;576345
So these colors should be the new go to colors yes?  Could probably start doing whole WYSE replicas with these if they turn out right.
« Reply #359 on: Mon, 16 April 2012, 18:39:08 »
+1 for Wyse replica GB!!
Offline shawn o
« Reply #360 on: Mon, 16 April 2012, 19:54:01 »
My WYSE keycaps look nothing like those colors. That WYSE pictured by 7Bit is much rarer version.
I have WYSE PCE 840358-01 and lettering is so dark blue its nearly black. And keys are dark grey (GTD) and almost tan not even close to GSX color above.
Its not fading either....
If those are the colors you're going with, I want my money back. This should have been decided BEFORE having people pay.....
« Last Edit: Mon, 16 April 2012, 19:56:44 by shawn o »
Offline Denonic
« Reply #361 on: Mon, 16 April 2012, 22:00:26 »
Quote from: shawn o;576507
Is it really that different?  The model I have is the one pictured here http://www.ebay.com/itm/Wyse-PCE-Keyboard-Wyse-901865-Wyse-840358-01-Wyse-901866-Wyse-841038-Wyse-900233-/350556978002?pt=COMP_EN_Workstations&hash=item519ed2fb52
It looks damn close to the one you've got apart from the black strip up top instead of grey and my keys look like this:
Now take into account real world lighting differences and the fact that different cameras capture colors slightly different and different monitors display colors slightly different and I think there isn't much in it between my image and 7bits.
Also, in my room lighting the dark grey looks tan and the blue legends look almost black like you described.  Shining a bright white LED over it, (or doing a proper white balance) gets it to look like my image above.  My previous color estimates were from images posted by others and some fiddling in Photoshop.  There was no guarantee that they would have matched.  7bits require no fiddling in photoshop and look pretty much as close as any of the other images.
Offline 7bit
  • MX1A-G1DW
« Reply #362 on: Tue, 17 April 2012, 15:14:58 »
You need a color sample ring to see if these colors mtch or not. If your key caps are yellowed, you need to compare them at the underside.
To match new keys with old yellowed ones, you should sunbath them until they match!
Offline inlikeflynn
  • file not found
« Reply #363 on: Tue, 17 April 2012, 22:29:15 »
This slacker is paid up at last now too
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline Quarzac
  • A very busy dude!
« Reply #364 on: Wed, 18 April 2012, 21:12:42 »
7Bit's seem to match almost perfectly. Shawn, I think yours would probably look the same under identical lighting and maybe with some retrobriting, but if you really want to cancel your order, shoot me a PM.
Offline shawn o
« Reply #365 on: Wed, 18 April 2012, 21:52:39 »
No, not going to cancel!
Offline Quarzac
  • A very busy dude!
« Reply #366 on: Mon, 23 April 2012, 14:34:33 »
Alright, I'm going to shake down the last couple members, since at this point they've gotta pay or we can't run addons. I'll let you guys know when I finally order.
Offline captain
« Reply #367 on: Tue, 24 April 2012, 13:51:18 »
I might take a set from a deadbeat, just to have On hand And I won't even whine about the tilde. ;-)
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #368 on: Tue, 24 April 2012, 13:57:32 »
Quote from: captain;580955
You have some Extra Capitalization there, my good sir.  How disrespectful of you!
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #369 on: Tue, 24 April 2012, 14:02:14 »
I don't think you should, because it is not grammatically pleasing.
Offline Quarzac
  • A very busy dude!
« Reply #370 on: Tue, 24 April 2012, 15:39:11 »
I'd need someone to take on an extra addon kit or two to be able to drop the other orders successfully. Except if I drop all the base kits from those orders, we're below 75 (73). So if people want to take a couple extra so I can scrap those orders, PM me. I think I need 2 base kits and 1 addon kit. More wouldn't hurt though.
Offline Quarzac
  • A very busy dude!
« Reply #371 on: Thu, 26 April 2012, 15:30:33 »
I need someone to pick up 1 base kit and one addon kit! If you're interested, PM me!
Offline Quarzac
  • A very busy dude!
« Reply #372 on: Sat, 28 April 2012, 23:20:05 »
I will be placing the order on Monday! Orders and collections are now officially closed!
Offline lowkey
« Reply #373 on: Sat, 28 April 2012, 23:36:21 »
Great! Can't wait.
Offline poxeclipse
  • Hit me with music ... yes, me friend
« Reply #374 on: Sun, 29 April 2012, 01:21:57 »
Quote from: Quarzac;583046
I just did.
tks
Offline dirge
« Reply #375 on: Sun, 29 April 2012, 02:26:34 »
Managed to fińd a UK ISO thick shot set for a fiver :) bring on the mooglz! Yellow as hell mind too
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline AKIMbO
  • HHKBro
« Reply #376 on: Sun, 29 April 2012, 14:25:45 »
I just realized I had a nearly complete WYSE set.  I didn't know the enter key, shift keys, and ctrl keys fit.  This set looks amazing on this board...I can't wait till the Moogle kit comes in.  Hurry up SP!
| KBD75 (box reds)
Offline sth
« Reply #377 on: Sun, 29 April 2012, 16:59:38 »
Quote from: AKIMbO;585709
Yeah, I too am really only waiting on the bottom row of 1.25 modifiers and a spacebar. It's going to look so good!
Offline Quarzac
  • A very busy dude!
« Reply #378 on: Mon, 30 April 2012, 20:50:44 »
The order has been placed!
« Reply #379 on: Mon, 30 April 2012, 20:51:56 »
Huzzah!
Offline AKIMbO
  • HHKBro
« Reply #380 on: Mon, 30 April 2012, 22:07:55 »
Quote from: Quarzac;586896
Nice...did we end up going with the color choices 7bit picked out?
| KBD75 (box reds)
Offline shawn o
« Reply #381 on: Thu, 03 May 2012, 13:25:07 »
The keycaps on WYSE 840358-1 are light beige. The legends look black, but are dark navy.Same for 840338-01.
On 840358-13, the keycaps are light grey. The legends look closer to blue, lighter than those on 840358-1.
Most of them are made in Taiwan, but some in China.
Offline 7bit
  • MX1A-G1DW
« Reply #382 on: Thu, 03 May 2012, 13:34:47 »
Quote from: shawn o;589219
Do you've got pictures?
Are they NIB?
Offline shawn o
« Reply #383 on: Thu, 03 May 2012, 15:16:31 »
I'm assuming the ones you have been posting pics of are a 840358-13?
Offline Soulpyre
« Reply #384 on: Sun, 06 May 2012, 20:15:45 »
Is there anyone who doubled their order who is looking to sell off an extra base kit? Please send me a PM.
TX 1800 - 62g Clears
KMAC LE - GON's Nerd PCB 62g Clears
KPAD - 62g Clears
KBT Race - Browns, Ducky Shine 4 - Browns
Offline sth
« Reply #385 on: Sun, 06 May 2012, 20:16:15 »
soulpyre YGPM in just a sec.
Offline shawn o
« Reply #386 on: Sun, 06 May 2012, 21:14:05 »
What keyboard was 7Bit using for color matching? Hopefully it was the more common 840358-1. Everything else is nearly impossible to get.
Offline biochem
« Reply #387 on: Mon, 14 May 2012, 19:02:29 »
Can hardly wait for these. My Filco needs some WYSE moggle love.
[ Attachment Invalid Or Does Not Exist ] 50249[/ATTACH]
Filco MJ2 tenkeyless (blues)
Heatware
Offline lowkey
« Reply #388 on: Tue, 15 May 2012, 14:10:30 »
Quote from: biochem;592795
(Attachment Link) 50249[/ATTACH]
Yeahhhhh same here.
« Reply #389 on: Tue, 15 May 2012, 22:06:58 »
My CMstorm needs WYSE love as well.
[ Attachment Invalid Or Does Not Exist ] 50511[/ATTACH]
Offline Quarzac
  • A very busy dude!
« Reply #390 on: Wed, 16 May 2012, 00:51:40 »
Does anyone have an extra base kit coming in? I've got a guy who's interested, but since I couldn't really order any extras, if he could pay one of you guys for one, and then I just ship it to him, that would probably work out well for all parties involved. PM me and I'll point you in the right direction. Also, don't be a **** about it. Sell it at cost. He's a nice guy who wants in on a nifty little buy that probably won't be run again. After they come in and they're yours, you can inflate them on the classifieds for all the chumps who totally missed it.
Offline sth
« Reply #391 on: Wed, 16 May 2012, 00:53:51 »
Yeah I can let one of mine go.
Offline dirge
« Reply #392 on: Wed, 16 May 2012, 02:19:53 »
Quote from: Quarzac;593797
^ we need more posts like this.  Like a bot that posts in every marketplace thread :)
Offline Quarzac
  • A very busy dude!
« Reply #393 on: Sat, 26 May 2012, 13:34:27 »
Guess what just arrived at my house? A giant box of keycaps! The dark keys match my WYSE set perfectly, and the light ones are a tad too light compared to mine, but mine could use a little retrobriting. I'll get them out ASAP, though it may be a bit. I'm in my last week of school, and then I'll get them on their way.
Offline dirge
« Reply #394 on: Sat, 26 May 2012, 13:51:08 »
Pics!
Offline AKIMbO
  • HHKBro
« Reply #395 on: Sat, 26 May 2012, 13:55:35 »
Quote from: Quarzac;600739
ˇPics por favor!
| KBD75 (box reds)
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #396 on: Sat, 26 May 2012, 14:41:29 »
Si!  Pictures will hold us over until you can get them shipped out later today.  ;-)  JK
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
Offline N8N
« Reply #397 on: Sat, 26 May 2012, 17:25:59 »
Crap.  Take some time off and what happens, someone makes a wyse moogle kit.  Well if anyone ordered extras or if there are leftovers, I need one...
Offline Quarzac
  • A very busy dude!
« Reply #398 on: Sat, 26 May 2012, 18:28:21 »
I didn't order any extra, but I know a lot of members probably have an extra set or two. Shoot a PM to sth and see if he wants to unload another, and I'll invoice it up. Also, I'll take pics tomorrow in natural light, because warm house lighting ruins colors and I'm terrible at taking pictures.
Offline Quarzac
  • A very busy dude!
« Reply #399 on: Sat, 26 May 2012, 20:40:05 »
I took a quick picture since I had some time. The flash on my phone overblows the color difference, though you can tell my caps are yellowed. It's the reproduction enter and |\ surrounded by a shift and a backspace pulled off a WYSE board.
[ Attachment Invalid Or Does Not Exist ] 51588[/ATTACH]
