Author Topic: Raising keycap height.  (Read 4005 times)
Offline Slyce
« on: Mon, 27 February 2012, 03:18:11 »
So I recently bought some keycaps from a group buy and they sit about 1-2mm lower then the rest on my board.
I can feel it (believe it or not) and it is really bugging me.
Is there a way to boost a keycap up a bit?
Thanks,
Terran player for LiNK Gaming
« Reply #1 on: Mon, 27 February 2012, 08:17:46 »
If you have an extra key to sacrifice, you can cut a bit off a stem and add a spacer ring to these.
Some of the kinesis guys have done this to get the thumb keys to work out.
Offline Slyce
« Reply #2 on: Mon, 27 February 2012, 14:53:47 »
In my defence this post is after I ordered the keys I am referring to.
Could try some surgery I guess... thanks.
