Author Topic: USB 3.0 Card  (Read 2440 times)
Offline SmallFry
USB 3.0 Card
« on: Mon, 27 February 2012, 16:12:14 »
I have been building a PC from some older hardware, so nothing too powerful, however I do want to eventually invest in a USB 3.0 Card. I want one port to be internal so that I can connect the front USB ports to it. I also want to have at least 2 ports in the back, I haven't found much for my requirements. Any suggestions?
Offline alaricljs
  • I be WOT'ing all day...
USB 3.0 Card
« Reply #1 on: Mon, 27 February 2012, 16:20:39 »
Really?  Took me a few seconds on google to find a card on amazon
Filco w/ Imsto thick PBT
Offline SmallFry
USB 3.0 Card
« Reply #2 on: Mon, 27 February 2012, 16:30:32 »
Syba has really bad reviews from what I've been researching. I saw their cards, they fit my needs and budget perfectly, but I don't want to waste my money on a worthless card.
Offline IvanIvanovich
  • Mr. Silk Underwear
USB 3.0 Card
« Reply #3 on: Mon, 27 February 2012, 16:30:52 »
Maybe something like this might be of interest. No idea about how legit this site is, but they are very hard to find these type with internal header and external port, usually one or the other.
Offline alaricljs
USB 3.0 Card
« Reply #4 on: Mon, 27 February 2012, 16:35:03 »
There's only 1 USB3 chipset that I'm aware of, how bad could they have screwed it up?
Offline alaricljs
USB 3.0 Card
« Reply #5 on: Mon, 27 February 2012, 16:40:13 »
NewEgg has the SIIG version of the card... identical aside from SATA instead of Molex for power.  That and 5x 5* reviews.
Offline alaricljs
USB 3.0 Card
« Reply #6 on: Mon, 27 February 2012, 16:44:02 »
So I just learned that there are indeed more than 1 USB3 chipset out now... Via (crap!) and TI... The SIIG card above has the TI chip.
