Author Topic: What Model M connection is this?  (Read 4525 times)
Offline Roguemaster8
« on: Tue, 28 February 2012, 02:03:58 »
This picture is taken from the back of a Model M 1390120 that was manufactured in January 1987.
I knew the earlier models used AT connections but was wondering if a PS/2 cable from Unicomp would fit and work just as well.
[ Attachment Invalid Or Does Not Exist ] 42032[/ATTACH]
Thanks for the help, I've never owned a Model M before, so my knowledge of them is fairly limited.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
fossala
  •  Guest
« Reply #1 on: Tue, 28 February 2012, 02:06:05 »
SDL. Doesn't say much as both ps2 and at connections used SDL's as there socket.
« Last Edit: Tue, 28 February 2012, 02:37:55 by fossala »
« Reply #2 on: Tue, 28 February 2012, 02:11:23 »
The one I'm looking at doesn't come with a cable, and researching it I found out it uses an AT cable.
Does this mean I would need to buy an AT cable and then an AT to PS/2 converter to get it to work?
fossala
  •  Guest
« Reply #3 on: Tue, 28 February 2012, 02:29:51 »
The model number you are looking at seems to be an AT model.
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/9231/subcatid/0/id/112510
« Reply #4 on: Tue, 28 February 2012, 02:35:47 »
I see, thanks for the link.
Does anyone know of a retailer selling AT cables?
fossala
  •  Guest
« Reply #5 on: Tue, 28 February 2012, 02:40:13 »
I cannot find any, at the cheap price of model M's in the US wouldn't it be just cheaper to get a ps/2 model?
« Reply #6 on: Tue, 28 February 2012, 03:03:42 »
Wanted the 1390120 for collecting reasons, and also found a cheap sale for one for $15.
Just was checking to see if finding an AT cable was possible. Or if I could interface it some other way.
« Reply #7 on: Tue, 28 February 2012, 07:39:18 »
The 120 should work with either cable, AT or PS2, black or beige. I have never had a 120 but I have had a couple of 131s and I think they are the same.
I am pretty sure that the originals came with a "short" black coiled cable with the large 180 degree DIN connector. That one should work with a DIN-to-PS2 adapter.
Those would be less desirable for someone actually using the board, but I understand that you want the old one for collecting. I might have 2 of those, if I find the extra I would consider selling it to you.
- D Trump 2026-10-24
« Reply #8 on: Tue, 28 February 2012, 13:28:26 »
Thanks for all the replies. I would like to start a collection but having fully working models would be nice too.
