Author Topic: Gaming mouse with low force buttons  (Read 4968 times)
Offline Obsidian
« on: Wed, 29 February 2012, 05:37:56 »
Hi all
Looking to replace my Razer Diamondback mouse, and I'm having some trouble finding something which meets my requirements. One of the most important features for me is the amount of resistance provided by the left and right buttons, but with no store to go to and try a variety of mice out it is very hard to know which mice will work for me. This issue isn't something that reviews tend to comment on. I am very suspicious of designs like the Steelseries Xai where the buttons are part of the body, as previous mice I have had in this style have been quite stiff, which I find uncomfortable. The Diamondback has been superb in this regard, with very light and responsive buttons. However, I'm not sure I want to buy a Razer again due to reliability issues.
I don't particularly need high dpi or tons of buttons, I just want a reliable optical/laser mouse with nice ergonomics and low activation force buttons. Any suggestions?
« Last Edit: Wed, 29 February 2012, 07:05:25 by Obsidian »
Offline Henry Allen Venture
« Reply #1 on: Wed, 29 February 2012, 07:35:31 »
You might want to consider the DeathAdder reboot.
I know its got the buttons that are part of the body, and its a Razer, but I've had no durability issues with mine after two-and-a-half years of constant abuse, and its buttons are definitely more sensitive in comparison to my Xai.
Just a suggestion - I'm sure there are others, but I've had my Xai and DeathAdder for a while now, and haven't had problems with either.
Current collection:
Filco Majestouch 104-Key, w/ MX Browns
IBM Model M 52G9700
Leopold FC200R, "white" w/ MX Clears
Ducky DK9008S \'Shining\', white backlit w/ MX Blues
Cherry G80-3494(LCYUS-2), w/ MX Reds for Portal Mod
Not mine, but I\'ve got access to:
Filco Majestouch Linear R Limited Edition, w/ MX Reds
Filco Majestouch 2 \'Ninja\' Tenkeyless, w/ MX Blues
Leopold FC500R, w/ MX Browns
Offline AeneaS
« Reply #2 on: Thu, 01 March 2012, 14:01:06 »
The R.A.T.7 is very reliable.
pros: build quality, very responsive buttons, heavily customiseable (height, length, width, exchangeable palm rests/rightside grips) even the position of the thumb rest can be moved forward/backward. You can palm grip it, claw grip or fingertip grip it and adjust its weight (although it is quite heavy already withot weights so I use it without any weights) Very responsive and good mouse wheel (way better than any razer mousewheel (had Razer Copperhead, Lachesis and Imperator)
cons: a bit heavy, a bit expensive
I just love the build quality of that mouse, the buttons don't get that shiny look threw extensive use like the razer mice do.(the mouse button of my razer lachesis looks like it was polished on the position where my finger was ^^) Overall highly recommended
I use it on 800/1600dpi mostly. No idea how the laser performs on other surfaces but on my Razer Goliathus textile pad it works like a charm.
If I would want a cheap and good mouse I prolly would go for the CM Spawn (but havn't tested that one...) Overall I'd say the R.A.T.7 is much better quality than all Razer mice in terms of buttons / customiseablity that I've had.
Don't like the Razer Deathadder too much because it is primarily made for palm grip, you maybe can claw grip it but its not optimal in my opinion...
« Last Edit: Thu, 01 March 2012, 14:08:23 by AeneaS »
