Author Topic: Keyboard Backlight Remains on after shutdown + First Mech  (Read 1358 times)
Offline VictimRAID
« on: Wed, 29 February 2012, 07:01:00 »
Hi guys,
I just got my first mechanical keyboard a Ducky DK9008 Shine (Cherry Blue) and when using the keyboard via the PS/2 adapter the back light remains lit after shutdown.
I have never used a back light keyboard via PS/2 (i used my old keyboard a Logitech G110 via usb) the only other PS/2 keyboard i own is a Dell SK-8110.
Are PS/2 ports constantly powered? or is there another reason power remains to the PS/2 port?
Any help would be appreciated :)
Offline VictimRAID
« Reply #1 on: Wed, 29 February 2012, 07:15:57 »
-Removed-
Offline Vyr1s
« Reply #2 on: Wed, 29 February 2012, 07:21:26 »
should be a BIOS setting. I believe if you have it set to be able to turn your system on via keyboard command it will keep the PS/2 lit up.
Offline Kamikaze K
« Reply #3 on: Wed, 29 February 2012, 07:23:20 »
Yeah just go into your BIOS and switch it off. Easy.
FILCO Majestouch 2 Camouflage Tenkeyless [Black]
DUCKY DK9008 Shining [Blue]
CM STORM Quickfire Rapid [Red]
TOPRE REALFORCE 87U
Offline VictimRAID
« Reply #4 on: Wed, 29 February 2012, 07:27:40 »
what do you think is better to use? PS/2 or USB?
Offline Kamikaze K
« Reply #5 on: Wed, 29 February 2012, 07:39:59 »
I usually use PS/2.... If you got the N-KRO option, why not use it!
TOPRE REALFORCE 87U
Offline Tony
« Reply #6 on: Wed, 29 February 2012, 09:41:38 »
PS/2 is faster. It uses internal interrupt, not usb input buffer.
