Author Topic: New vintage model m's  (Read 2168 times)
Offline dirge
« on: Wed, 29 February 2012, 13:20:27 »
http://www.ebay.co.uk/itm/130653272743?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/130653272951?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Both actually in the US, for the love of god someone here who wants em get em.  They don't deliver to the UK so I'm weeping!
Thinking about things isn't the same as doing things. Otherwise everybody would be in jail.
Offline BiNiaRiS
« Reply #1 on: Wed, 29 February 2012, 13:30:03 »
They are terminal boards, so they aren't gonna work without a controller swap and adding a cable.
KMAC 2 w/ErgoClears
Offline Ascaii
« Reply #2 on: Wed, 29 February 2012, 13:44:22 »
These are ridiculously simple to modify using a controller from a busted 1391401. The plate and barrel assembly has a ribbon cable that plugs into the controller pcb...a simple swap, done in less then a minute, and you have yourself a working, NOS board.
Offline Roguemaster8
« Reply #3 on: Wed, 29 February 2012, 14:14:25 »
You would still have to bolt mod it because of the plastic rivets though right? I thought after 20 years they decayed and fell out.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
Offline REVENGE
« Reply #4 on: Wed, 29 February 2012, 15:00:58 »
Quote from: Roguemaster8;531075
Only if you're afraid of the...
Ping.
fossala
  •  Guest
« Reply #5 on: Wed, 29 February 2012, 15:02:47 »
Quote from: REVENGE;531127
Ping.
You don't bold mod for ping. You bolt mod for a uniform feeling over the board. As rivets fail the board looses its tension and the keys feel uneven and in extreme cases fail.
Offline BiNiaRiS
« Reply #6 on: Wed, 29 February 2012, 15:15:36 »
Quote from: Ascaii;531036
True, but that is just more cost added to the boards that weren't super cheap to start with. Lack of LEDs will dissuade some people as well.
Brand new in plastic bag seems weird too...unless that is how they were sold OEM?
KMAC 2 w/ErgoClears
Offline KillerBee
« Reply #7 on: Wed, 29 February 2012, 21:05:01 »
The bag is new the model m is used... j/k ;
IBM Model M 1386304 Nov. 1985
