Author Topic: Where can I get custom Spacebars for my Leopold Tenkeyless Tactile Click Keyboard  (Read 3045 times)
Offline lROOl
I emailed WASD and they said that their spacebars are not compatible, anyone know where I can get some?
I have a black one know and I want to get some keycaps made and the black just wont look good with what I want.
Thank you
Offline IvanIvanovich
  • Mr. Silk Underwear
KBC has universal that are Leopold compatible, but I am not sure if they are yet available in their full color range. I know black and white are available for sure. Otherwise you can buy a matching one from wasd and cut the stems and epoxy them back in the Leopold spacing. If you don't want to do it yourself, see here.
Offline lROOl
can i get a link to the KBC ones.. I actually just need white
thanks again
Try pm imsto.
