Author Topic: To those who want "special" Topre  (Read 897 times)
Offline jrockroll
« on: Thu, 01 March 2012, 09:37:46 »
They are making 2nd "special" 10th anniv. Realforce Keyboard
It doesn't have the ANSI enter. Looks like Realforce91.
Only 1000 will be produced! Now who's interested?
It has a special 10th anniv. sign on the top right corner :D
http://www.kbdmania.net/xe/3693893#34
Offline reaper
« Reply #1 on: Thu, 01 March 2012, 09:41:22 »
Nice find.  It looks the same as the last one tho plus that BIG ASS enter turns me off. :nono:
« Last Edit: Thu, 01 March 2012, 09:44:52 by reaper »
Din Eli
Offline jrockroll
« Reply #2 on: Thu, 01 March 2012, 09:43:40 »
I heard the small spacebar reduces sound :D
Offline guilleguillaume
« Reply #3 on: Thu, 01 March 2012, 09:49:02 »
Quote from: jrockroll;531989
Yes it does. Is nearly the same size as the right shift from ANSI/ISO layout if not the same. Also it's PBT.
I quote my message from Deskthority:
Quote from: guilleguillaume
For me what completely ruins the keyboard are those spaces without keycaps making the keyboard 89 keys instead of 91 keys. They're not like the Realforce 106 that is part of the shell:
Those holes seem like those Access-IS MX keys that are completely flat to fill switches you're not using.
