Author Topic: Problem with US international keyboard layout: dead keys produce double characters  (Read 3145 times)
Offline Dajm
I'm using the US International keyboard layout, which allows me to have access to French and German special characters.
It worked fine until 2 days ago. I have no idea what triggered this, but now, whenever I push the key for single quote, I get 2 single quotes on the screen.
If I push the key for a double-quote, I get 2 as well.
Same thing for the tilde-key and same thing for "shift 6": I get 2.
This means I'm currently not able to write any of the French letters with accents nor any of the German Umlaute.
From what I see, all keys that are supposed to be dead keys in this layout are acting up. Instead of waiting for my next input, it gives me 2 of whatever I pushed.
I have no clue what could have triggered this.
I think it can't be my keyboard's fault, since, if I switch to "English (US)" (the normal one, not the international one), everything is normal and quotes and double-quotes work fine.
This is on Windows XP, in case that matters.
I have another computer here with XP as well and the US international layout works fine without problems on it.
Any ideas? Am I missing something?
Is there maybe some weird Ctrl-Alt-something combo I might have accidentally pushed that could have caused my problem?
Offline Dajm
Nobody with an idea of what it could be?
It''s driving me crazy! Aah! See? Two single quotes!
Offline Dajm
Solved it. As incredible as it sounds (at least it did to me), the cause was a virus.
While I was working, all programs I had open (Outlook, Firefox, Skype, etc) suddenly shut down and a window appeared telling me I had a virus and I should run a scan and buy this software, blablabla. Your typical scam.
Long story short: Malwarebytes took care of the issue and everything's back to normal.
