Author Topic: Corsair 550d pre order $140.68 on amazon  (Read 2506 times)
Offline Tricks
« on: Fri, 02 March 2012, 09:45:17 »
well I am waiting for this case for a while and found a good deal I guess on amazon, it will probably be an excellent case!
http://www.amazon.com/Corsair-Obsidian-Series-Mid-Tower-CC-9011015-WW/dp/B006L6ZSWC/ref=sr_1_1?ie=UTF8&qid=1330703048&sr=8-1
EDIT:
Its 139.99 on newegg and in stock, just ordered it with a bunch of other stuff :)
« Last Edit: Fri, 02 March 2012, 16:22:13 by Tricks »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Fri, 02 March 2012, 19:58:06 »
Might be able to get the $20 rebate as well if you didn't notice that.
Filco w/ Imsto thick PBT
Offline Tricks
« Reply #2 on: Fri, 02 March 2012, 23:03:51 »
yeah saw that, am kinda lazy, but u r right!
Offline Anyguy4321
« Reply #3 on: Sat, 03 March 2012, 22:40:01 »
Looks like a fantastic case.  Was looking at the Nzxt h2 Black myself but I think I will need a larger case to future proof myself.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Sun, 04 March 2012, 01:23:10 »
What about the Fractal Design R3 cases? Emphasis on quietness also, but at a lower cost.
Offline Tricks
« Reply #5 on: Sun, 04 March 2012, 12:17:37 »
I was debating between Fractal and Corsair, but I think the build quality might be superior with Corsair, also the weight is very much something I factor in:
Fractal Design Define R3
Dimensions 20.85" x 8.17" x 17.4"
Weight 27.56 lbs.
Fractal Design Define XL
Dimensions 22.10" x 9.13" x 22.05"
Weight 39.50 lbs.
Corsair 550D
Dimensions 20.9" x 8.7" x 19.5"
Weight 16.5 lbs.
