Author Topic: Filco Full-size quality  (Read 2302 times)
Offline naranja
« on: Fri, 02 March 2012, 22:09:51 »
Was wondering if the full-size filco had the same misaligned up arrow that the TKL ones have.
[ Attachment Invalid Or Does Not Exist ] 42499[/ATTACH]
Offline jellowiggler
« Reply #1 on: Sat, 03 March 2012, 12:50:31 »
Really?
Is the pic just not showing the problem well?
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline naranja
« Reply #2 on: Sat, 03 March 2012, 13:00:45 »
Someone mentioned that their full size ninja is aligned well so I guess that answers my question.
Really?
It doesn't seem a little towards the right to you?
more references: http://geekhack.org/showthread.php?22680-Filco-Camo-build-quality-prob
Offline Awful
  • Don't Topre.
« Reply #3 on: Sat, 03 March 2012, 16:03:20 »
Mine isn't like that on my Filco tkl.
I hate everything.
Offline naranja
« Reply #4 on: Sat, 03 March 2012, 16:17:56 »
Quote from: Awful;534158
do you have a pic of your arrows to share?
Offline CaiSter21
« Reply #5 on: Sat, 03 March 2012, 17:42:05 »
before ripster comes in here with some witty remark, there is nothing wrong with the arrow keys.
its just the McRip Effect
Ducky Shine DK 9008S Red LED |Rosewill RK-9000BR
Offline naranja
« Reply #6 on: Sat, 03 March 2012, 17:55:36 »
Quote from: CaiSter21;534204
Couldn't care less if it's categorized in the McRip effect. It is misaligned enough for me to notice. Just wanted to know if the fullsize had the same misalignment.
For those that still don't see it: http://geekhack.org/attachment.php?attachmentid=28098&d=1318094696
Offline Tony
« Reply #7 on: Sun, 04 March 2012, 01:29:27 »
Please learn to touch type, then you will not be so nitpicky and perfection oriented.
Offline naranja
« Reply #8 on: Sun, 04 March 2012, 01:49:59 »
Quote from: Tony;534604
I get about 80wpm; I'm also nitpicky/perfection oriented. Nothing wrong with wanting my keyboard how I want it :D
Offline elef
« Reply #9 on: Sun, 04 March 2012, 02:23:20 »
As far as I can tell, the up arrow key on my fullsize is properly centered. I don't care either way, though. I don't see the slight misalignment as a problem.
Offline naranja
« Reply #10 on: Sun, 04 March 2012, 02:24:27 »
Quote from: elef;534677
Yeah, It seems that way from what I see from other posts. To each his own though.
Offline Roguemaster8
« Reply #11 on: Sun, 04 March 2012, 03:51:21 »
You want to talk about alignment, have you seen the Unicomp Spacesaver case?
Look at my avatar, that Esc key barrel is off center by a full 2 mm. It would bother me more if it just wasn't the way they're built.
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
