Author Topic: Filco TK Pad!  (Read 2965 times)
Offline captain
Filco TK Pad!
« on: Sun, 04 March 2012, 09:24:41 »
This would be a great addition to a TenKeyLess Filco!   [strike] I don't find the in the USA, alas. [/strike]
http://www.filcochina.com/Products_TKPad.asp
Found it!
http://www.amazon.com/Majestouch-TenKeyPad-Tactile-Numberpad-FKB22MB/dp/B000MGBPNI
There is a TKPad company out of Texas; GoldTouch. I wonder which is better.  They have a Mac and a Windoze version, but aside from an extra key, and different codes sent, I can't get a straight answer from them.
http://www.amazon.com/gp/product/B003Q9HAOG
« Last Edit: Sun, 04 March 2012, 09:39:39 by captain »
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
Offline Human
Filco TK Pad!
« Reply #1 on: Sun, 04 March 2012, 10:24:06 »
Quote from: captain;534853
Found it!
IIRC, in the buying guide wiki once listed a Goldtouch/Kinesis Numpad rebrand, infact it is a generic with no branding one.
It is quite cheap(around 15/20 USD, not too sure) and being sold by an ebay seller from Hong Kong.
Though, the listing seems to be expired, not sure if there still anyway to get them this cheap.
Offline captain
Filco TK Pad!
« Reply #2 on: Sun, 04 March 2012, 10:35:32 »
The GoldTouch uses MX Browns, I believe. I asked if they could do Blues, and never heard back from them. :-P
Offline Human
Filco TK Pad!
« Reply #3 on: Sun, 04 March 2012, 10:45:49 »
Quote from: captain;534907
I do come across GoldTouch Numpad with MX black when I surfing through taobao for 2nd hand junks. That should mean that they existed.
Though I do feel that they(black) are on the rare side as most of them are browns.
http://item.taobao.com/item.htm?spm=11020U0p.3-a715N.h-4ovqkx&id=12789827232&
« Last Edit: Sun, 04 March 2012, 10:49:27 by Human »
Offline nhwhaup
Filco TK Pad!
« Reply #4 on: Sun, 04 March 2012, 11:50:33 »
I have the exact same one that you show from the China website.  It has the brown switches and I do use it to compliment my Filco TKL with reds.  Really wish the number pad also had the reds but it serves the purpose.  If I remember correctly I bought my Filco TKL on amazon and the number pad from The Keyboard Company.
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline silat
Filco TK Pad!
« Reply #5 on: Mon, 05 March 2012, 14:24:21 »
10Key?
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline IvanIvanovich
  • Mr. Silk Underwear
Filco TK Pad!
« Reply #6 on: Mon, 05 March 2012, 14:40:12 »
I had a goldtouch, it had MX blacks. In my opinion neither is better, but the Kinesis is. Yes it is technically the exact same thing as the goldtouch, but with one nice difference, a 2 unit 0 key. Much easier to use all those leftover Cherry numpad keysets:thumb:
Offline Typhaeon
Filco TK Pad!
« Reply #7 on: Mon, 05 March 2012, 14:45:42 »
B... but it has more than ten keys.
Offline Typhaeon
Filco TK Pad!
« Reply #8 on: Mon, 05 March 2012, 15:00:54 »
'I guess "seventeenkeyless" just doesn't have the same ring to it.  I'm voting the acronym be supplanted by "SKL", if only because there are so many other acronyms with which to confuse hapless readers.  For example, are you buying a harmless keypad peripheral, or Kaiser Wilhelm's entire naval admiralty?  These are the important questions in life.
Or "StKL", since there doesn't appear to be any Wikipedia entry with that letter combination.  It probably stands for something in German, though.
Offline boredgunner
    • GND-Tech
Filco TK Pad!
« Reply #9 on: Mon, 05 March 2012, 18:30:57 »
On the subject of numberpads/tenkeypads, this one isn't Filco but is it any good?  Their keyboards are listed in the buying guide so I guess it might be.
http://www.newegg.com/Product/Product.aspx?Item=N82E16823166110
There is no direct note on the switch type it uses, but the description suggests Cherry MX Blues.  Their website also shows a picture of a numberpad with the keys removed, and Cherry MX Blue switches under.  The price is good so if nobody has used it, I might try it.
Ducky Shine II TKL (Green LED, Cherry MX Red) | Leopold FC210TP (Cherry MX Blue)
Offline squarebox
  • In Omnia Paratus
Filco TK Pad!
« Reply #10 on: Mon, 05 March 2012, 18:51:54 »
Isn't TK = Team Kill?
I wonder what's happening to the current generation of homo sapiens.
Filco Yellow Edition  | Filco Brown | Filco 2 Brown TKL | G80-1950 | G80-3494 | G80-11900 | Leopold FC500R | Noppoo Choc Mini
Offline boredgunner
    • GND-Tech
Filco TK Pad!
« Reply #11 on: Mon, 05 March 2012, 19:48:22 »
Quote from: ripster;536217
Well, just because it is in the WW Shopping Wiki doesn't mean it has my seal of approval.  I have all the Duckys and even Qpad in there.
The keyboards had so-so reviews.
I might have to take the leap of faith then!
Offline captain
Filco TK Pad!
« Reply #12 on: Tue, 06 March 2012, 14:09:07 »
Quote from: boredgunner;536278
Get the Addesso and the GoldTouch and do a comparison review!  :-)
