Author Topic: Recognizing keyboards by sound  (Read 1190 times)
Offline Pyretti
« on: Sun, 04 March 2012, 09:43:38 »
Hi there!
Every time I hear someone typing on a keyboard I try to recognize the keyboard by the sound it makes. I do this especially when watching movies.
My friends reactions are quite priceless when I tell them: "That guy in the movie has to be using a buckling spring keyboard!"
It just sort of naturally to me...
Are you guys also trying to recognize the keyboards you happen to hear?
Offline kaiserreich
  • HHKB Elite
« Reply #1 on: Sun, 04 March 2012, 09:49:05 »
People around me tend to use scissor switches and Cheap rubber domes, I can tell the difference immediately.
As for sound between Browns and Clears, that is a bit harder.
Offline Human
« Reply #2 on: Sun, 04 March 2012, 10:27:00 »
Quote from: Pyretti;534871
Hi there!
You trust the sounds from keyboards in movies?
Seriously I won't do it. I assume that those sounds are most probably being tuned or added to give you the feel of the actors are typing. I though so because there is no way for scissor-switch/rubber dome to be that much clickly and loud in real world...
It is more accurate to blindfold typing on it than listening to it.
Offline Surly73
« Reply #3 on: Tue, 06 March 2012, 07:15:28 »
It seems just about every movie uses a Cherry MX for keyboards, even if that's not what's pictured in the actual film.  Sure, I can tell buckling spring, from Cherry from Topre, but I would never expect to be able to tell the sound difference between the Cherrys (blue excepted, of course).  Modding Cherrys with O-rings would throw that off too - it's usually the distinctive bottoming out sound that tells me Cherry.  In my limited-compared-to-some experience with Topre, it sounds pretty distinct too.
