Author Topic: can you identify this keyboard?  (Read 1215 times)
Offline KLIK
« on: Sun, 04 March 2012, 12:58:27 »
Can someone identify this keyboard? I got it from a friend. There's only one number on the back.
 I wonder if it's compatible with a PC, because I don't want to damage my motherboard.
WYSE 900840-02
IBM Model M 1391406 / DELL AT101W / APPLE EXTENDED II
Offline REVENGE
« Reply #1 on: Sun, 04 March 2012, 14:28:09 »
Quote from: ripster;535046
Oh, you mean the OTHER one.
Looks like some generic AT clone.  Have you plugged it into a PC yet?  Use a PS/2 port.  They are fairly useless these days.
I'd actually guess WYSE for that one as well.
Offline mich
« Reply #2 on: Wed, 07 March 2012, 08:07:19 »
Looks like it might indeed be XT or AT compatible. Either should be perfectly safe to connect to PS/2, but only AT will work.
Could you post a close-up of the corner with this big chip, resistors and cable connector?
Offline Snarfangel
« Reply #3 on: Wed, 07 March 2012, 11:05:43 »
Quote from: ripster;537825
While waiting for the OP I know a good Polish Keyboard joke.
Anybody want to hear it?
Polish keyboard? Oooh, shiny!
Offline SidusNare
  • Do, or do not; there is no try.
« Reply #4 on: Wed, 07 March 2012, 11:11:18 »
Those caps look kinda nice
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
Offline KLIK
« Reply #5 on: Wed, 07 March 2012, 11:40:09 »
I checked and this baby is incompatible.
White-out from what;)?
thanks for help guys.
WYSE 900840-02
