Author Topic: CamelCase?  (Read 1771 times)
Offline HapticBovinator
CamelCase?
« on: Mon, 05 March 2012, 08:46:56 »
Hi,
I'm new so don't flame me too hard for this, but what is 'Camel-Case'? It is a 'feature' listed for the doubleshot replacement gb.
I know if I am coding e.g. in C++, and I name a class FooBarBaz, or a method fooBarBaz(), that is called 'camelCase' because there are 'humps' in the middle of the lexeme to signal to the reader that is to be read as two or more words.
Is it e.g. the funkiness of the shift key with multiple height levels?
Code: [Select]
   __
 _/  \_
CamelCase?
« Reply #1 on: Mon, 05 March 2012, 09:02:21 »
I think that 7bit meant that the legends are written with an initial capital for each word. For example: "Back Space" instead of "Backspace".
BTW, you have worked with haptics?
CamelCase?
« Reply #2 on: Mon, 05 March 2012, 09:21:41 »
Quote from: ripster;535666
Camelcase keeps your cameltoes warm and protected.
(Attachment Link) 42762[/ATTACH]
oh god no
Quote from: Findecanor;535674
ty sire. I think some of the indicated "camel case" boards had all caps, maybe not, I'll double check.
No, but I am saving cell phones for a project. I think I have ~10 cell vibrator motors (please rip no comments about vibrating camel cases :). I was thinking about a haptic feedback belt. We'll see.
« Last Edit: Mon, 05 March 2012, 09:28:43 by HapticBovinator »
CamelCase?
« Reply #3 on: Mon, 05 March 2012, 09:31:25 »
Do all "spherical" keyboards have these multiple height levels?
Code: [Select]
  __
 _/  \_
CamelCase?
« Reply #4 on: Mon, 05 March 2012, 14:17:19 »
Quote from: HapticBovinator;535706
Code: [Select]
  __
 _/  \_
All the ones in R4 SPH do have the "sculpted" profile ('cept the funciton keys, which I believe are row3?), but you can get them all flat profile, like what Deck has (though Deck's keycaps aren't spherical).
