Author Topic: What Cherry keyboard has.....  (Read 1936 times)
Offline shawn o
« on: Thu, 08 March 2012, 16:52:18 »
Trying to leaver about the variations in Cherry keyboards so I can complete my doubleshot set for use on a Filco.
Is there a Cherry that uses a flat, center stem, 1.75 capslock key?
And regarding the 1.25 modifiers, is there a single Cherry board that has center stem 1.25 modifiers?
I have seen this G80 and it has a flat capslock but not sure its center stem (same for modifiers).
http://www.ebay.com/itm/CHERRY-G80-8113HRDUS-2-PS2-BLACK-/350453630416?pt=PCA_Mice_Trackballs&hash=item5198aa05d0
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1 on: Thu, 08 March 2012, 18:17:37 »
Quickest way, is 1 Cherry g80-8113, and 1 Cherry G81-8000. You will get everything you need in those 2 boards for ANSI, for the lowest price. Got a problem with used? Get the same 8113 for $35. Yes the 1.25 are normal centered stem, as with all MX boards (excluding common caps lock). They only do that off center crap on MY.
Offline shawn o
« Reply #2 on: Thu, 08 March 2012, 23:24:19 »
That particular one on auction has laser keys right?
« Reply #3 on: Fri, 09 March 2012, 11:38:52 »
Grrr. I only looked for that seller as they had a bunch of doubleshot ones a few days ago... picture is a doubleshots one... I saw it and paid no attention to the model number. You might ask them if they happen to have any HRCUS left, you might get lucky. Sorry.
Offline shawn o
« Reply #4 on: Sat, 10 March 2012, 16:39:10 »
Thanks, used is OK. Got some used keys this week on here so I just need the caps lock, shift, and modifiers now I believe.
