Author Topic: Question for Deck users...  (Read 2809 times)
Offline Tallon
« on: Sat, 10 March 2012, 00:16:38 »
//EDIT//
I've done some more research (including reading the friggin' 140 page thread over at ocn on the ducky shine... ugh). While I love my das silent - I remember the first time I tried the keyboard I felt the keys were too light. It's been a year and I still think they're lighter than I'd like. I still want a tactile response, which leaves only one option - mx clears.
Which means getting a deck (because I don't want to mod ;P ). That leads me to another question specific to the deck ...
A major concern I have with the deck is that the keys are all level. The closest thing I have to this is a laptop keyboard, which I don't like. I'm not sure if that's a really fare comparison, though, since laptop keyboards are quite different and are easy to typo on (imo). What do you guys think? Is it an issue? Am I just overthinking this? :)
The only other option I can really think of is if I decide to forgo the back lighting and get a realforce (such as the 55g uniform).
//END EDIT//
Ok, so I purchased a Das silent keyboard a year ago, and I absolutely love it. But, I often find myself wishing I had a backlit keyboard. Yes, I type in home row very well - but sometimes backlighting can be darn useful :).
Anyway, it looks like xarmor's company is completely gone now - so I don't want to go with one.
Some of the things I'm looking for - I'd prefer a keyboard that connects via usb, BUT can connect via ps2 with an adapter. I currently need ps2 so my keyboard can start my computer (long story short - my power button on the tower is broken). I'd only go for brown or clear switches. USB ports aren't necessary, but are a plus.
It seems like the "best" backlit keybaord is the deck legend, though it requires a lot more work to switch from USB to PS2.
Anyone have any ideas? It's been a long time since I've keyboard shopped! It seems like there's been plenty of new keyboards, but few if any are backlit. Any help would be appreciated...
-Tallon
« Last Edit: Sat, 17 March 2012, 16:57:37 by Tallon »
Offline Encryptor
« Reply #1 on: Sat, 10 March 2012, 00:31:54 »
You could get the PS/2 version of the Deck legend and a PS/2 to USB adapter.  Not all of them will work with the Deck due to its current draw.  The one I have is this translucent blue one from ebay and it works fine.
The reason I went this route is so I can have N-key rollover via PS/2 but can still plug it into devices that don't have PS/2 ports via USB.
There's also the Ducky Shining that has MX browns, but I have no idea how much current it draws and which USB->PS/2 adapters would work with it.
Offline Awful
  • Don't Topre.
« Reply #3 on: Sat, 10 March 2012, 01:22:39 »
^those
If you want a full sized Obey the Ducky
I hate everything.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #4 on: Sat, 10 March 2012, 02:16:53 »
Quote from: Tallon;540794
-Tallon
I have a DAS silent as well and all I did was install all white PBTs and you can easily see them in the most dimly lit room.
Remember you are working with an LCD/Monitor that is already putting out a lot of light.  The all whites simply amplifies itself for easy spotting in the darkest rooms.
Try it, in the end self-lighted keyboards become redundant.  I got rid of a ducky shine and a K90, don't need them anymore.
Offline Tallon
« Reply #5 on: Sat, 10 March 2012, 10:55:45 »
Wow - lots of great advice! I'll have to look into all of these when I get back home later today...
-Tallon
Offline Tallon
« Reply #6 on: Sat, 17 March 2012, 14:14:20 »
(moved text to first post)
« Last Edit: Sat, 17 March 2012, 16:58:12 by Tallon »
Offline Tallon
« Reply #7 on: Sat, 17 March 2012, 14:49:02 »
lol...
and thanks ripster, for the link to the buttons. I'm going to have to rip apart this case and see if the problem is something I can easily fix, or if I need to switch out the button with one you linked to.
Offline silat
« Reply #8 on: Sat, 17 March 2012, 18:58:49 »
Quote from: ripster;541049
Dude, get the top quality Elevator Style Metal switches from Performance PCs.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=4056&zenid=57c7fb8378df4680ff872ef01f68265c
rip that is awesome. Thanks for the tip.
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline silat
« Reply #9 on: Sat, 17 March 2012, 19:00:50 »
Quote from: Encryptor;540804
This adapter works with win 7?
