Author Topic: MODEL M (AT connector) not working anymore  (Read 790 times)
Offline bolthar
« on: Mon, 12 March 2012, 10:27:39 »
Hi everybody,
    I've been using this keyboard for more than 5 years now and it suddenly just died on me a couple of weeks ago. It's an AT and I use a PS/2 adapter.
At startup, the two caps lock and screen lock leds blink for a brief moment, then the numlock led blinks for a moment too, then nothing - it's exactly as the keyboard were disconnected from the PC. If I move the connector a bit, it does the same trick (caps and screen blink, then num, then nothing). I've tried changing adapter but it doesn't work, it seems that the issue is either on the cable itself or the bus on the keyboard.
There's no chance I can find a replacement for the cable (I'm in Italy, I've looked everywhere on the internet) and getting a "new" model m is also extremely difficult, I would probably have to buy a unicomp from oversea and that would be more than 150$ with shipping. Plus I'm very attached to this particular piece of hardware :-)
What can I do to at least understand what exactly is wrong with the keyboard? I'm afraid to cut the cable or even open the carter...
Offline bolthar
« Reply #1 on: Mon, 12 March 2012, 15:31:40 »
Up... I'm really sorry to up this thread but I really need your help guys :-( I have no idea where to start from. I've googled extensively but I can't find a thing related to my specific issue and I'm afraid to break everthing if I do things myself :-( I'm more than willing to do my homework, I just need a pointer...
Offline mbc
  • -delete-
« Reply #2 on: Mon, 12 March 2012, 18:33:29 »
Open the keyboard and check if  grounding etc are still in place.
Offline mich
« Reply #3 on: Thu, 15 March 2012, 11:44:50 »
Looks like a cable failure, unless you are moving this plug enough to disconnect it from the socket.
