Author Topic: Which keyboards come with doubleshots already on them?  (Read 5680 times)
Offline MyNameIsFinn
« on: Tue, 13 March 2012, 16:19:32 »
What the title says, I wanna do some ebay snooping.
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
« Reply #1 on: Tue, 13 March 2012, 16:23:40 »
OR with high quality keys
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
Offline Roguemaster8
« Reply #2 on: Tue, 13 March 2012, 16:26:16 »
Older Cherry keyboards are the only ones I know of, but if you can't find those, go for ones that come with PBT caps.
Like a Unicomp.
EDIT: I found one: http://www.ebay.com/itm/CHERRY-G81-1822HQMUS-PS2-BLACK-KEYBOARD-/230618121302?pt=PCA_Mice_Trackballs&hash=item35b1e94456#ht_500wt_1180
« Last Edit: Tue, 13 March 2012, 16:31:26 by Roguemaster8 »
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
« Reply #3 on: Tue, 13 March 2012, 16:39:03 »
Quote from: ripster;544855
See the Anti-Otaku Filco mod post.  Go to Mods subforum and click on sort by views and it should float near the top.  Ask questions in the mod post if you have any.
Thanks ripster
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
Offline silat
« Reply #4 on: Tue, 13 March 2012, 16:45:29 »
Ripster would you please tell me what is the reason people want these keys? What keyboards do people want them for?
Fighting the Christian American Taliban daily with my Deck Legend loaded with Cherry MX Clears //
Deck Legend Ice Clears // Deck Legend Frost Clears // Ducky Shining Purple Browns//QPAD MK85 Browns //
Offline keyboardlover
« Reply #5 on: Tue, 13 March 2012, 18:06:47 »
This is also mentioned on my website. Click the sig yo!
« Reply #6 on: Tue, 13 March 2012, 18:30:21 »
Quote from: ripster;544875
All in the Anti-Otaku post.
Feel free to ask questions there.
Quote from: keyboardlover;544983
Or, you can ask questions about keycaps in the keycaps subforum and get an answer there *gasp* !
Quote from: silat;544874
Anyway, People seem to like doubleshots. They are always ABS plastic, but the legends are shot "through" the keycap and won't fade until you've worn through the entire keycap. I have a set of used cherry doubleshots, and they look really nice, with the white lettering on black keys. The legends look really sharp.
Personally, I prefer PBT, but the cherry doubleshots are very nice. It's really the only thing I use that's not Dyesublimated PBT. The legends are a little "blurrier" on the PBT dyesubs.
The alphanumeric keys should work on any cherry MX-compatible(filco majestouch, leopold, CMstorm QF rapid, Poker, etc.) keyboard, but you often need to get other keys for capslock, control, alt, windows, menu, spacebar, and sometimes shift. These are usually made as "moogle" kits. Check the GB forum for some good ones.
Offline silat
« Reply #7 on: Tue, 13 March 2012, 19:52:29 »
Thanks for the lead rip....
Offline silat
« Reply #8 on: Tue, 13 March 2012, 19:55:11 »
Dork that was very informative. I appreciate it.
« Reply #9 on: Tue, 13 March 2012, 21:16:57 »
Sometimes the **** rip posts makes me happy he is here
Inb4 qft
[SIGPIC][/SIGPIC]
Filco TKL MX Brown
Offline Ahlitah
« Reply #10 on: Tue, 13 March 2012, 21:53:15 »
don't the deck legends have double shots?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #11 on: Wed, 14 March 2012, 00:11:38 »
Cherry G80, G81 models that the first letter in model is H
Wyse / Reynolds / Link / etc terminal boards.
BTC / Leading Edge  / etc 5300 series
Those are just the MX (compatible) ones that are really common and often cheap. There are also loads of Alps and other switch type boards that have doubleshots too that you can get often for under $40.
« Last Edit: Wed, 14 March 2012, 00:17:05 by lysol »
« Reply #12 on: Wed, 14 March 2012, 00:39:20 »
Quote from: Ahlitah;545226
sort-of. The process involves multiple pieces of plastic, but the "shot" doesn't involve an injection molding machine the same way a traditional doubleshot does:
http://geekhack.org/showwiki.php?title=All+About+Keys (search for "deck"). They have an insert that is likely dyesublimated, then forced into a plastic skirt.
Offline whiskerBox
« Reply #13 on: Wed, 14 March 2012, 01:22:14 »
Never know what you'll find in salvage stores (goodwill, salvation army etc.).
I have found several interesting boards with double shots for under $3.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
Offline omuerte
« Reply #14 on: Wed, 14 March 2012, 02:34:52 »
Quote from: whiskerBox;545425
Standard pc keyboards or POS boards?
Click Clack
