Author Topic: Just bought this and i have a few questions  (Read 1844 times)
Offline LEGITBALLIN
« on: Sat, 17 March 2012, 14:25:06 »
how can i hook it up to a pc and also how much is it worth it has cherry blacks and doubleshot keycaps its made by wyse.
V-tec just kicked in yo\'
fossala
  •  Guest
« Reply #1 on: Sat, 17 March 2012, 14:38:35 »
You cannot hook it up to a PC unless you fancey coding a teensy.
P.S. You got bored with the trolling?
Offline LEGITBALLIN
« Reply #2 on: Sat, 17 March 2012, 14:42:18 »
what do you mean is this specific keyboard not good for coding i just want to try some blacks for fps i already have a das which i use to code and type
fossala
  •  Guest
« Reply #3 on: Sat, 17 March 2012, 14:44:21 »
Re-read what I posted.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sat, 17 March 2012, 14:51:53 »
They use terminal signaling, so are unusable on a PC without replacing the controller. It is moddable, but you would need to invest the time and effort to that. There was a step by step write up on how to do it somewhere. To answer your other question, about $30.
Offline LEGITBALLIN
« Reply #5 on: Sat, 17 March 2012, 14:52:00 »
i code java but i still dont get it
« Reply #6 on: Sat, 17 March 2012, 14:52:11 »
It's a terminal board. You'll need a teensy for it to work with USB.
Board is worth 40 if new
Offline LEGITBALLIN
« Reply #7 on: Sat, 17 March 2012, 14:53:12 »
ok that helps thanks
fossala
  •  Guest
« Reply #8 on: Sat, 17 March 2012, 14:57:03 »
How was my post so hard to understand? It is not like I write in hyrogliphs.
Offline Human
« Reply #9 on: Sat, 17 March 2012, 15:02:52 »
Quote from: fossala;549075
You probably should write in troll language for his better understanding.
