Author Topic: [curious] Matte Das Keyboard case?  (Read 6666 times)
Offline Kazen
« on: Sun, 18 March 2012, 15:39:16 »
so guys. I wonder, Is there any info on what kind of plastic the Das keyboard casing is made off? I wonder if i coud make it more matte by using something like paper or sanding on it, as i think that would look a whole lot better then the glossy finish it has now.
Offline mcsnails
« Reply #1 on: Sun, 18 March 2012, 16:03:41 »
somebody did this a little while back here
Offline Kazen
« Reply #2 on: Sun, 18 March 2012, 16:47:47 »
wow, thanks for the link :)
Offline anselben
« Reply #3 on: Tue, 27 March 2012, 03:01:41 »
I'd think if you were going to do something you should just try and wrap it. I think that what the person did made the keyboard look awful.. and plus that would be permanent. If you did something like that then were like "**** this sucks" then it'd be a bummer. Sometimes I feel like I'm the only one who like my shiny das :(
