Author Topic: Anyone know where I can find a wireless MX blue keyboard?  (Read 1774 times)
Offline Krishna Pterofractal
« on: Mon, 19 March 2012, 04:02:42 »
Anyone know where I can find a wireless MX blue keyboard? Do they even exist? I couldn't find anything but wireless MX Brown keyboards.
Thanks,
Krishna
Offline Human
« Reply #1 on: Mon, 19 March 2012, 06:14:21 »
IIRC, Xarmor/Qpad do made something called U9W b4, which is a wireless mechanical keyboard.
The next bet is to get a Neo Zelia 87(by whatever mean you can) from taobao can mod it to blue by yourself.
BTW, according to your post, you are able to find wireless MX BROWN board? What is it?
Offline omuerte
« Reply #2 on: Mon, 19 March 2012, 06:30:31 »
It'd be a fun project to find both a ps2->usb controller as well as a USB-> bluetooth controller ;)
You could do a lot with that pair.
Click Clack
« Reply #3 on: Mon, 19 March 2012, 13:48:32 »
Offline Human
« Reply #4 on: Mon, 19 March 2012, 15:05:52 »
Quote from: Krishna Pterofractal;550688
http://www.amazon.com/XArmor-U9W-wireless-mechanical-keyboard/dp/B004S862FW was the MX Brown keyboard that is wireless.
Then your only way probably is custom stem mod. It should be easy to be done on Neo Zelia as it is PCB mounted.
« Reply #5 on: Mon, 19 March 2012, 15:21:35 »
Thanks for all the help.
